Need some help!
Old Sep 21, 2014 | 10:27 AM
  #51
98hotrodfatboy's Avatar
98hotrodfatboy
Default All Bent Up
Hey bro, hope you didn't bend a valve or damage the piston. Good Luck...
Old Sep 21, 2014 | 10:34 AM
  #52
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You said that you had air leaking past the exhaust valve, while the pushrod was removed.
The bent pushrod was not causing this, since it was not installed in the engine.
The bent pushrod is just collateral damage.
The pushrod was adjusted too long, and when the engine rotated the valve collided with the piston, bending the valve and the pushrod.
Once you get the head repaired, I suggest you question your pushrod adjustment procedure, it is a simple process, but easily misunderstood.
Old Sep 21, 2014 | 11:00 AM
  #53
Schex's Avatar
Schex
The Harley dealer would my last choice, find a local indy, maybe he can repair it in house, or lead you to a machine shop they would use.
If the seat and guide are OK, you could probably just get a new or even good used valve, lap it in, new stem seal, and go, since it sounds like your not going to get both heads fully reworked.
Old Sep 21, 2014 | 12:16 PM
  #54
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by 95 Ultra
Ok, got the head off. It's a bent pushrod. It's obvious to the naked eye. I'll take the head to the local Harley dealer tomorrow and see if they can rework it. I don't know if they do their own work or send it out. I installed new lifters and adjusted the pushrods the last time about a year ago. I've probably ridden it 6-7 thousand miles since then. If I had adjusted the pushrods incorrectly then, wouldn't I have had a problem before now? Anyway, it's gonna get fixed next week. It's been an aggravating week to say the least. Thanks everyone for all the advice and suggestions. Ole Blue will run again. KC.
I found this a while back posted here but I don't remember who posted it.
First put the bike in high gear and rotate the wheel forward until the valve to be adjusted just closes.
Then put a piece of tape on the bottom of the wheel.
Next rotate the wheel forward until the valve starts to open, put another piece of tape on the wheel.
Halfway between the two marks will put that lifter on the heel of the cam.
Now you can adjust that valve.
We usually add a quarter turn or so extra to make up for loss of length when tightening down the pushrods. Hope this helps.
Old Sep 21, 2014 | 04:16 PM
  #55
texashillcountry
Dirt don't hurt
This is just a thought but since you have to take the head off then if you go back with solid pushrods you don't have to worry about not adjusting them correctly.
That is what I did when I redid my top end gasket set.
Old Sep 21, 2014 | 04:43 PM
  #56
Dun Roamin's Avatar
Dun Roamin
I'll give that a thumbs up. JET make a nice set. They are cheap enough and claim to be more accurately measured than OEM, which doesn't surprise me.
Now you have your heads off, take your time to set the squish height and/or chop a little off the heads. It's cheap to do.
Johnsons (JET) also do made to measure or -0.050" short ones if you do.
Old Sep 21, 2014 | 09:46 PM
  #57
miacycles's Avatar
miacycles
THC,
That would be me. It was the easiest way to have a novice get it right !!!
John
Old Sep 21, 2014 | 10:16 PM
  #58
D_gyver's Avatar
D_gyver
here's what I think happened his 2 year old lifters were stuck when he adjusted them it just opened the valve and never bled down. turned the motor over and bent the valve and pushrod
Old Sep 21, 2014 | 10:26 PM
  #59
WP50's Avatar
WP50
Originally Posted by miacycles
THC,
John
THC and I were talking (phone) a bit ago and your input came up about when I was chasing a vib in my 97 EG
So it was You
Respects WP
Old Sep 22, 2014 | 05:56 AM
  #60
texashillcountry
Dirt don't hurt
THC,
John
Thanks for the reminder John.
I have a word file just for the gems I find here and that was one of them.
williamf57
EVO
21
May 11, 2013 06:27 AM
noridinsavage
EVO
18
Sep 15, 2011 11:43 AM
cbaker1@farmersagent.com
Apr 19, 2011 11:47 AM
SD_Nick
Jun 14, 2010 07:56 PM
TREV35
Exhaust System Topics
11
Feb 17, 2008 07:20 AM
