Engine won't fire
Hey guys. I posted this in the electrical section as well, but I thought I'd try here too. Any help is appreciated.
Ijust put my engine back together with 95" pistons, ported heads, roller rockers, adjustable pushrods,and .560 lift cams. I did most of the disassembly and assembly, but had my indy install the cams. I tried to fire it up last night, but it wouldn't start. The engine turns over, it's getting fuel, and I've got spark, but it won't fire. I've checked all the electrical connections that were disconnected (mostly at the induction module), and everything is securely plugged in.I was concerned that I may have reversed the plugsto the injectors, but they're on correctly. I'll pull the tank off tonight to get a better view of everything, but I don't think that is the problem.
My only other thought is that the cam timing marks may not havebeen properly aligned. I'd hate to pull everything necessary to get the cams out unless it's absolutely necessary. Does anybody have any ideas on what to check? Any advice is greatly appreciated.
sporty79
13
Aug 17, 2007 12:15 AM
