S&S eazystart cams with ACRS ?
Old Sep 4, 2016 | 08:40 PM
guesscrazy's Avatar
guesscrazy
Default S&S eazystart cams with ACRS ?
Can S&S eazystart cams be used with automatic compression releases ? Any issues or concers?
Old Sep 4, 2016 | 10:52 PM
cdonis's Avatar
cdonis
I am and disabled the acr with my pv2 tuner.
Old Sep 4, 2016 | 11:00 PM
Wv7o's Avatar
Wv7o
As far as I know (and I could be wrong) S&S makes 2 versions of each cam they make one with EZ start and one without, just get the version without and just use your ACR's.
If you have a Power Vision you can disable your ACR's, or you can get the dealer to disable them.
Not sure if unplugging your ACR wiring will cause a code on your bike but starting could be an issue using EZ start cams and electrical ACR's at the same time.
If I would have had ACR's I would have chose the non EZ start cam that went into my engine.
Is the cam you are looking at not offered in a non EZ start version? Just wondering why you are considering EZ start cams if you already have ACR's.
Old Sep 5, 2016 | 12:05 AM
Next In Line's Avatar
Next In Line
Easy start cams bump the exhaust valve open a bit while starting. If you are using ACRs on top of that, I don't think there would be enough compression to start the engine.
Old Sep 5, 2016 | 05:25 AM
joe40x's Avatar
joe40x
Actually the combination of the two work really well together. I've been running mine for three years with no problems...starts right up every time. It also seems to be fairly easy on the battery as mine is four years old and still going strong.
jbrelr21
Engine Mechanical Topics
15
Mar 6, 2015 08:42 PM
Mikeduke108
Aug 5, 2014 04:39 PM
Big Blue Bike II
May 20, 2012 08:46 PM
mgmmgm
Exhaust System Topics
Mar 13, 2010 06:22 AM
jaguar
Ironhead
Jan 1, 2007 09:27 AM
