Gear Cams...Shaft run-out?
Old Feb 1, 2008 | 12:32 PM
fryeca's Avatar
fryeca
Default Gear Cams...Shaft run-out?
Dropped by the Indy today and talked about doing a gear cam (I'll be doing it myself), he said the first thing to check before I attempt this would be to check the main shaft run-out; I wasn't aware that there was a fair amount of bikes that have tolerances out of spec that a gear cam will not work...he said if I'm over spec then I would need a new crank or stay with the chain driven cams.
I'd hate to tear-down getting ready for my install to gears and find out at that point gear camsare not an option becausemy crank is out oftolerance?
I have a sneaky suspicion that this is why HD runs chain cams to begin with and not that EPA bull$hit about noise!!!!!!!!!!!!
Old Feb 1, 2008 | 03:05 PM
dawg's Avatar
dawg
Default RE: Gear Cams...Shaft run-out?
ORIGINAL: fryeca
Well duh!
Tear it down, check tolerances and if ok go gears, if not go roller chain conversion.
Old Feb 1, 2008 | 03:53 PM
mtclassic's Avatar
mtclassic
Not that big of deal to check the runout. I checked mine before I ordered my gear drives to be on the safe side. I think you are crazy not to check but 1000's have never checked and run gear drives. I figured if my run out was over spec I would go with the roller chain conversion while I had it apart. Mine were in spec. I helped my buddy with his and his were like .0035 and fairly low mileage bike around 35,000 miles on an 05. mine is an 04 and had ~52,000 on it and mine were ~.0015. It is a total crap shoot.
Old Feb 2, 2008 | 07:36 AM
fryeca's Avatar
fryeca
I was told that I should take the entire cam-chest out to do a proper run-out check?
Old Feb 2, 2008 | 08:00 AM
glide's Avatar
glide
ORIGINAL: fryeca
YouTube - 2007 Harley Davidson 96 Twin-Cam Pinion Shaft Runout
YouTube - 2007 Harley Davidson 96 Twin-Cam Pinion Shaft Runout Part 2.
Old Feb 2, 2008 | 09:11 AM
fryeca's Avatar
fryeca
Damn GLIDE! Nothing better than a video to show ya how it's done!
Thanks Man!
Old Feb 2, 2008 | 10:05 AM
glide's Avatar
glide
Like they say....one picture is worth a thousand words
Old Feb 2, 2008 | 12:47 PM
Neckball's Avatar
Neckball
Pulled mine down today with the intention of installing Andrews 26G cams and a gear drive conversion. Runout is .004-.0045, no gear drive for me. Time to go to plan B. Either stay with the stock chain tensioner setup or do the later style cam plate/oil pump conversion. Bike is a 2005 RK Classic, 47,000+ miles. Outer tension shoe looks great, about .022-.025 wear. I'll post a few pics later.
Old Feb 2, 2008 | 01:25 PM
mtclassic's Avatar
mtclassic
ORIGINAL: Neckball
Neckball, did you have your dial indicator exactly prependicular to your shaft? If you did not have it at a perfect 90 degrees it will not be accurate and will actually show more run out than you really have. The video above is excellent.
Old Feb 2, 2008 | 04:09 PM
fryeca's Avatar
fryeca
What's the max run-out allowed to use gear cams?
