Carburetor Cough
Old Feb 2, 2006 | 05:07 PM
jcarlos's Avatar
jcarlos
Default Carburetor Cough
What’s the problem when your carburetor coughs, as you release the throttle to take a turn and then give it some gas half way throught the turn?
Old Feb 2, 2006 | 05:39 PM
HDF Tech's Avatar
HDF Tech
Default RE: Carburetor Cough
Sounds like it has a cold...
Really, it sounds lean and probably is, what mods do you have, any?
Give some more info and maybe we can help you out here.
You could richen it up some without any mods at all and make it run better.
Old Feb 2, 2006 | 05:40 PM
ThudMeister's Avatar
ThudMeister
Yes, I was going to say don't they make a Robitussin for that?
Old Feb 2, 2006 | 08:26 PM
jcarlos's Avatar
jcarlos
I'm running an S&S Super E Carb on a 97 Heritage Springer FLSTS, I'll check the carb, maybe I am running to lean. Thanks for your reply.
Old Feb 3, 2006 | 11:25 AM
HDWRENCH's Avatar
HDWRENCH
What intermediate jet and main are your using?? Do your tuning with the accel pump turned off, and dont forget that you will have to split the difference with low and and top end with a S&S. Most times you end up with a great running bottom end and a flat spot in the mid range or the other way around. Most time the flat spot occurs inthe cruise range so owners tend to have them a bit rich in the low end to stop the stumble ot flat spot as the carbs gets into transition from low to high speed. There are a few ways to make the carb perform better, De Vincie kit or a thunder jet with a external air bleed. The carb only has two curcuits so you are spliting the rpm range of the engine in two where as the cv has 3 which allows for better tuning.
David Glover
EVO
11
Aug 1, 2013 07:44 AM
Tromp
Apr 6, 2013 07:21 AM
CSS_FXD
Sep 23, 2011 09:34 PM
snvts82
Apr 27, 2011 03:39 PM
wallybally
Apr 3, 2008 12:26 AM
