Faulty Valve guide seals
Old Feb 6, 2006 | 07:48 AM
Nitescan's Avatar
Nitescan
Default Faulty Valve guide seals
I don't post much....read mostly, but was wondering if anybody has heard about the 05 valve guide seals being faulty & causing some oil burning? It just came to my attention this weekend & I will call my dealer this week about it. Supposedly they are not saying it is a "recall" but acknowledge the problem. I have an 05 Road King Custom...................Thanks in advance for any information. I will post later what I find out from my dealer!
Old Feb 6, 2006 | 09:25 AM
HDF Tech's Avatar
HDF Tech
Default RE: Faulty Valve guide seals
Take a look here... https://www.hdforums.com/m_93573/tm.htm
Old Feb 6, 2006 | 12:46 PM
itsahog's Avatar
itsahog
ORIGINAL: Nitescan
My bike is in right now, just had the seals replaced under warranty. I have a 05 Deluxe. Look on your bike tag ID sticker, if it was built early it has the old seals. Mine was built in 10-04. I think after 1/2 of the year they used the proper seals. Check your plugs. Mine were a little wet, especially the rear one but my bike ran fine. I learned of the faulty seals here on this site. My dealer was great about replacing them. Good luck.
Old Feb 7, 2006 | 07:54 AM
Nitescan's Avatar
Nitescan
Appreciate the info here, didn't get to call dealer yesterday, maybe today. It doesn't burn any oil , haven't looked at the rear plug yet either[:@], I really wasn't too concerned with this issue because I haven't had any of the known symptons, but on the other hand I would just as soon get it looked at/serviced before it becomes an issue! Thanks again!
Old Feb 7, 2006 | 10:30 PM
springer_'s Avatar
springer_
You may also want to checkout this thread... https://www.hdforums.com/m_222244/tm.htm
The "faulty" seals were used throughout '05 and into '06.
Old Feb 8, 2006 | 08:00 AM
Nitescan's Avatar
Nitescan
Hey Thanks Springer.......execellent info. I'm trying to work a deal now with labor on a 95 or 98 kit, hopefully I can get it all done at once.
Old Feb 9, 2006 | 02:21 AM
sgu500's Avatar
sgu500
I was going through 1 quart of oil every 1200-1400 miles on my 05 RK Custom. When I asked the dealer about it last fall, they gave me a copy of the tech sheet and said that it was "normal". When I continued to ask them about it before X-Mas, they offered to do the valve guide seals under warranty and offered free pick-up and delivery. (Things are slow in Wisconsin Harley shops during the winter). They also offered to do the 95" big bore at the same time for cost of parts -20% and 1 hour labor since the motor would already be apart. So, the big bore work was less than $500. Just got it back and can't wait till it warms up!
Old Feb 11, 2006 | 08:40 AM
Tweet's Avatar
Tweet
2nd Gear
What Cams did you put in on the 95" set? I have the SE 203's and the Torque fine for a Big Tourer!
Old Feb 11, 2006 | 08:27 PM
itsahog's Avatar
itsahog
I also used the 203's. Too soon to tell as I am still in the break in stage.
Old Feb 11, 2006 | 08:36 PM
traveler's Avatar
traveler
Susie is an '05 and no problem yet!
joe
bdeuce
Nov 20, 2008 10:24 PM
bobs05deluxe
Jul 6, 2007 05:31 PM
M2hunter
Apr 16, 2007 11:33 PM
joe v
Nov 22, 2006 11:36 PM
Hog_fever
Jun 27, 2006 01:11 PM
