Cam advice for 96" Stage 1
RE: Cam advice for 96" Stage 1
If you are not going to do any head work I would recommend a cam that has less than 30 degrees overlap on these EPA motors.The tall gearing \\;on 07/08 models also add to problems with picking a cam that comes on to late.Also look at the intake closing.35 degrees or less will work best in these 96ers.Regards,Tom
RE: Cam advice for 96"\\\\\\\\\\\\\\; Stage 1
The 255 and the 253 are EPA cams...they got their start in the CVO bikes. Both of these cams will make power down low but fall on their face at 4200 rpms....the 204 will pull longer but won't touch the 255 for low end grunt. \\; The 26 will be the best choice for both worlds in a stock motor.
RE: Cam advice for 96"\\;\\\\\\\\\\\\\\;\\\\\\\\\\\\\\\\\\\\\\\\\\\\ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\; Stage 1
I have a very similar setup as you.
I as well as many others have had great success with Head-Quarters cams in the 96".
https://www.hdforums.com/m_2825599/tm.htm
Post #16 has the cams model and link.
Good luck.
Good luck.
