EVO in need of more power!!!
Hey how can I get some more power out of my EVO it's a 98 efi \\;cop bike with a d&\\;d fat cat exhaust. I'm lookin into performance shops or online like headquarters for some info??? Or let me know what combo your running and how much HP/Tq your pullin.... I just want more ummmph!
I'm located in Dallas Texas so let me know if there's anyone in the metroplex worth a flip workin on EVO's and making power!
Thanks
Thanks
RE: EVO in need of more power!!!
Well the MM system is one \\; downfall. \\;\\\\\\;With a good set of \\;\\\\\\; ported heads, ev3 cam or a woods 6 you can look to see 80+ hp and 90+ tq. On pump gas in high heat you have. Do you plan on on keep the efi system?? Most swap it out for a carb, easy swap really and will be easier in the long run. Most shops that you find are not into tuning the MM systems or poor at. There are some out there if you can find them that can do a good job. They are trouble some to say the least. We just finished a install on the new Zippers MM to delphi conversion I was extremely happy and the end result. It was the first we had done and the final product turned out great. We installed it on a 117 incher. 0 issues at all.
Question how does your bike run currently as far as start up , idle, drivablity?? It seems that some MM system run without issues other are don't. Seems to be a luck of the draw. \\; \\; If yours is a good running version , then leave it and find a tuner that knows MM injection. Make sure that you do have the larger injectors, easy to tell if they are red those are the larger versions.
Good tuners can get your Marelli system working just fine.
We must have done at least 75-100 80" Evo's over the years with a Bob Wood 6 and head mods.
They hang at about 80 hp and 90 ft/lbs.
Fuel economy goes up, as well as the fun.
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
