100 hp evo
Old Nov 12, 2012 | 06:21 PM
criccio's Avatar
criccio
6th Gear
Default 100 hp evo
Hello my motor head bros, just getting started on my first attempt to 100 hp out of my evo. So we have put together 10.5 .20 over forged pistons,lineweber E7 577 lift cam,jims forged 1.675 roller rockers,oversize manley valves,match polished and ported heads,single-fire dyna ignition,s&s super e carb,oversize 630 springs,titanium collars, then I also got rid of the stock 32-61 tooth spockets for a set of 31-70 tooth.If you see something I missed and should do please let me know.will send pics and Dyno results when finished.Thanks Bros and fellow gear heads.
Old Nov 12, 2012 | 08:28 PM
gsxrboy96's Avatar
gsxrboy96
Sounds like a solid combo, should come real close to 100hp, only things I'd change are the camshaft and carb, but that's only a matter of preference ! Good luck, chad
Old Nov 13, 2012 | 06:21 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
We have been at the 100 hp mark(on our site)many times.
All your ducks need to be in a row, for a "streetable" broad power curve.
A good exhaust will be needed for this, and we would highly reccomend a Thunderjet in that E carb.
Our combination has always been with a Wood 8 cam, for good low end, to peak rpm power.
Scott
Old Nov 13, 2012 | 06:05 PM
criccio's Avatar
criccio
6th Gear
as far as exhaust running big radius vance hines with some minor mods, as for the woods cam,that was my first choice but the lobe seperation was to far apart for a solid pull all the way thru,the lineweber lobe sep is very close at 108/106 quick to open quick to close should work better with this garbage fuel nowadays. Hopefully or will go back to plan A with the 630 woods.Thanks for the input.
Old Nov 14, 2012 | 05:46 AM
Hillsidecycle.com
Sponsor
The 8(only .590 lift) will do it, as will the 9B, 9F, and 6HF, as we have used them all in that application.
Scott
Old Nov 14, 2012 | 07:27 AM
gsxrboy96's Avatar
gsxrboy96
Agreed with the woods 8 recommendation...
Old Nov 14, 2012 | 08:05 AM
3408pete's Avatar
3408pete
Okay-----------------the way I take this is the engine will be 20 over but other wise its just the 80 inch bottem end??
Old Nov 14, 2012 | 01:02 PM
criccio's Avatar
criccio
6th Gear
Thanks for the feed back will def check on the woods.
Old Nov 14, 2012 | 01:04 PM
criccio's Avatar
criccio
6th Gear
yes it is only 80 inch.
Old Nov 14, 2012 | 01:14 PM
3408pete's Avatar
3408pete
thank you-----------------I cant break that 80 horse level cant wait .My exhuast hurts some but we tried others to no avail
