BLOWN ENGINE???????
Old Jul 14, 2008 | 09:29 PM
GREEN MACHINE's Avatar
GREEN MACHINE
Default BLOWN ENGINE???????
Wife was riding her Deluxe when suddenly it rev'd briefly, blew the dipstick out of the oil tank and started running on one cylinder. Plugs look good but fear I've got a possible hole in a piston. Any thoughts??
Old Jul 14, 2008 | 09:53 PM
2Sore's Avatar
2Sore
Default RE: BLOWN ENGINE???????
Same thing happened to a buddy of mine..piston ring cracked..destroyed the motor...sorry..hope your under warranty...
Old Jul 15, 2008 | 06:14 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Hopefully not as much harm as that.
Perfect time to turn lemons into lemonade.(more power with superior components)
Old Jul 15, 2008 | 06:16 AM
GREEN MACHINE
No warranty, its an 05.
Old Jul 15, 2008 | 07:29 PM
rbabos's Avatar
rbabos
ORIGINAL: GREEN MACHINE
You will discover that there may not be any compression on one cylinder. Hole or not it will be piston related somehow unfortunately.
Ron
Old Jul 15, 2008 | 07:40 PM
2005UltraNC's Avatar
2005UltraNC
Basically, the compression (of what's leftover) from one of the pistons got into the crankcase - so mush so to blow the dip stick.&nbsp\\; Compression check will show which one.&nbsp\\; Problem is what sort of pieces got into the oil.
Old Jul 15, 2008 | 10:39 PM
R1Geezrglide's Avatar
R1Geezrglide
A friend broke a rocker arm and produced a similar result. With a valve not opening, the piston continued to pump but with no where to go, the pressure went into the crankcase.
Old Jul 20, 2008 | 09:03 AM
GREEN MACHINE
To all that replied, thanks. I took it apart and found that the piston had started to melt. I ended up boring it out .10 over and cleaned-up the valves.
Old Jul 20, 2008 | 10:23 AM
R1Geezrglide
&nbsp\\;
I'd sure be looking for the cause of the piston damage.
thirdjoe
2014-2024 Touring Models
24
Mar 17, 2015 06:59 AM
Mudslinger64
Sep 4, 2013 03:16 PM
KeeBee
Mar 24, 2011 04:24 PM
GREEN MACHINE
Jul 15, 2008 06:19 AM
tatersalad
Mar 15, 2007 12:26 AM
