88" to 95 super stock
mikuni 42/45
You'll only need a 42 mik (IMHO) unless you go with big cams and headwork and want to get all the top end you can (and the 45 might gasp a bit under load at very low revs on a "mild" 95).
You don't even need the 42 - as already pointed out the stock carb will work fine (if you do the filter etc). However the 42 will give a nice crisp throttle response compared to a CV and once you've got used to that I doubt you'd want to go back - it will also support most upgrades you might be planning.
(I use a 42 mik on my 99 dyna - 95 CI and Andrews 37G with V+H Pro-pipe and it's great)
That's only my experience - and I'm not a technical guy. Good luck and hope whatever you decide works out for you
A 42 will do it, as will a Thunderjetted S&S.
On the flip side, you'd be mighty surprised as to what the CV will really do.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
