Big Bore Carb
Old Nov 22, 2012 | 06:10 PM
FL-kruzen's Avatar
FL-kruzen
Default Big Bore Carb
I will be installing a big bore kit on my 2001 FLHTC (EGC). I want to upgrade the carb and I was looking at the Mikuni 45mm HSR. Then I seen the S&S G carb. I'm not too worried about CV Carb as I live and ride in Florida. I'm very familiar with the Mikuni because I had one I installed on a Yamaha Road Star.
My question is will my stock air cleaner work with the Mikuni?
Old Nov 23, 2012 | 09:59 AM
grbrown's Avatar
grbrown
If you currently have a stock Harley c/v carb on your bike, that will easily deliver 100HP, so unless you are talking a serious upgrade, your current carb may be fine. Don't spend unnecessarily! As for going to a 45mm or Super G, they may be too big. I have a G on my S&S 107".
If you buy a Mikuni, get the kit that includes an air filter. Your stock air cleaner (assuming you mean the plastic airbox) is not suitable for your bike once you put your big-bore kit on, you will need an SE or K&N or S&S teardrop.
Old Nov 23, 2012 | 10:04 AM
95custmz's Avatar
95custmz
There is a kit available to adapt the Mikuni carb to stock a/c.
Old Nov 23, 2012 | 12:06 PM
Fastrider124's Avatar
Fastrider124
If you still running an 88 or even a mild 95, the Mikuni 42 is plenty. My 95 with Crane cams 316-2, ported heads, V&H propipe, 10.2 pistons did 93hp/98t. Excellent throttle response, good fuel economy, easy to tune.
The 45 is just too big imho, unless your running long duration high lift cams, and the G is way too big!! My S&S 124 uses the G!! fwiw Fastrider
cimnut
EVO
16
Nov 2, 2016 07:15 PM
parts eeter
Jul 30, 2014 01:27 PM
ptcruiser
Nov 26, 2010 03:11 PM
renegado
EVO
15
Nov 9, 2010 07:58 PM
badwiser
Jun 3, 2010 10:07 AM
