Installing studs?
Old Jun 4, 2005 | 11:45 AM
ScooterGuitar's Avatar
ScooterGuitar
Default Installing studs?
I would like to find a stud kit and put them on my saddlebags and seat. I have heard doing the bags would be simple enough, but the seat would be impossible w/o taking thew actual seat apart. Any ideas or knowledge of this? Think it owuld look mismatched if I only had studded bags and a plain seat?
Old Jun 4, 2005 | 01:20 PM
pococj's Avatar
pococj
Default RE: Installing studs?
You'll have to take the seat at least partway down. You have to be able to get something on the backside of the stud to install it with the setting tool. If it's a stock seat, it is probably just stapled to the seat base. Pry the old staples out, partially remove the cover, install the studs, put cover back in place, restaple. If it's a custom seat it is probably riveted. Drill the rivets, slip the cover, install studs, cover back on, rivet with blind (not regular) rivets.
Old Jun 4, 2005 | 01:47 PM
oldgeezer's Avatar
oldgeezer
Check around at a leather shop or a hobby place like Michaels or Snobby Lobby for stud kits. They should be considerably cheaper than at a bike shop. There are several different kinds. Most have tabs that go through the leather then bend over to secure them.
Old Jun 4, 2005 | 06:18 PM
John TN's Avatar
John TN
J&P Cycles has the kits as well, should look good. When you get the studs on, post a pic.
John TN
rob0225
Nov 13, 2020 06:15 PM
hardheaded
Apr 29, 2016 10:38 PM
paud
Nov 14, 2012 06:56 PM
Keener
May 10, 2010 09:37 PM
goforit06
Aug 13, 2006 11:22 AM
