Noise that comes and goes.
I got a noise the comes and goes. After the bike warms up, it shows up after running the bike for an 30 minutes at highway speeds. As the RPM drop below 25,000, I get what sounds like a tap that starts off with a tap the skips and then goes constant. It changes with engine speed. If I give the gas it goes away and as the RPM drops it comes back. If I stop for about 10 minutes, it goes away for a while.
It’s a 06 Ulta and with all the stuff on it I can’t figure out where the noise is coming from. The primary has the auto tension spring. Other than that the bike is stock with 43,000 on it.
Thoughts??
Thoughts??
