Leaky
Old Oct 2, 2006 | 02:51 PM
jhnmflr's Avatar
jhnmflr
Default Leaky
I have got a crank seal leaking . Apparently the crankshaft is slightly grooved . Anyone know of a sleeve/seal kit or saver seal kit .
The bike is a 87 fxtsc
Old Oct 12, 2006 | 02:18 PM
jhnmflr's Avatar
jhnmflr
Default RE: Leaky
Had to bump it
Old Oct 12, 2006 | 02:28 PM
04RoadKing's Avatar
04RoadKing
Default RE: Leaky
Sorry can't help ?????
Old Oct 12, 2006 | 09:08 PM
HDWRENCH's Avatar
HDWRENCH
Default RE: Leaky
Well you have a EVO and you are pumping engine oil into the primary correct. The seal rides on a spacer you can flip it around to ride in a new spot or replace the spacer cost on a spacer is approx 18 dollars.
Old Oct 13, 2006 | 01:49 PM
jhnmflr's Avatar
jhnmflr
Default RE: Leaky
Thanks , I have never had it apart . A local shop did the seal for me and 3 times the leak continues . Also doesn't seem they can get my belt drive back on right . Pretty much done everything else to the bike myself and being an 89 you can imagine there has been a lot . I think I will try them one more time and see what happens , if not I'll tackle it myself .
Appreciate the info .
Old Dec 2, 2006 | 11:40 AM
jhnmflr's Avatar
jhnmflr
Default RE: Leaky / update
well , had the shop try to fix the oil leak one more time to no avail . Finally got around to tearing it down myself and could nto see any problem with seal . The shaft they told me that was grooved was not . I bought a new shaft spacer and seal , install seal backwards because of the belt drive ( was told to do that ) .Put a sealer around outside of seal when installed . looked for any hair line cracks on the case also and didn't see any .Belt drive does not have a tensioner , possible to much tension on crankshaft causing leak ? Slap her back together start it up and remove outer primary . Look inside stator / case are and there is oil puddling in the bottom of the inner primary under crank / stator . I have checked my screen filter on block , rerouted my breather ( maybe restircted ) . Hell I'm at a loss now any suggestions would be great !!!!!!!!!!!!!!!!!!
Old Dec 2, 2006 | 12:10 PM
One_Screamin_Eagle's Avatar
One_Screamin_Eagle
Do you have the 2 little screws that hold the stator wire to the engine case intact and sealed? They are a direct hole right into the engine and need to be sealed. Oil will transfer through there if they are not there or not sealed.
Also, doesn't that case fall in the range of leaky inserts. There is a procedure to check that the oil isn't actually coming out between the aluminum case and the insert pressed into it (the one the crank passes through). That was a common to see back then.
Old Dec 2, 2006 | 01:03 PM
jhnmflr's Avatar
jhnmflr
I'll check the stator plug bolts . i don't know of the insert leak you are talking about , any idea on the leak check procedure ?
Old Dec 2, 2006 | 07:13 PM
jhnmflr's Avatar
jhnmflr
ORIGINAL: One_Screamin_Eagle
Gotta say thanks . never thought about the stator connector retainer . No boltw or hold down were present and someone had siliconed the holes . I put an oil dye in this afternoon and ran the bike . Took it apart and looked at h=that area an it was all yellow , bingo . Just gotta say thanx dude .
John
Sam01
Oct 2, 2018 09:28 AM
Wayne1853
Oil Archive (no new posts)
Mar 23, 2012 07:14 PM
Tactical111
EVO
19
Nov 8, 2010 05:41 PM
superant33
Jul 27, 2010 05:18 AM
2Shakes
Mar 22, 2009 11:29 AM
