Oil Archive (no new posts) An archive of oil related questions and comments.
'89 Evo Engine Leaking Oil
Old Mar 23, 2012 | 06:24 PM
Wayne1853's Avatar
Wayne1853
Stage I
Default '89 Evo Engine Leaking Oil
89' Evo Engine is leaking oil from the sprocket side of crankcase into primary. I replaced the sprocket shaft seal twice and it still continues to leak very heavily. I had heard of bad crank case castings during this year. Does anyone know of anything that could help me?
Old Mar 23, 2012 | 06:57 PM
NickD's Avatar
NickD
The stock seals are single lipped and meant to keep dirt and crude plus primary fluid out of the motor but not necessarily motor oil out of the primary. Since I run a dry primary (open belt drive) I flipped the seal around to prevent leaks from the crankcase. I also put high temp silicone around the seal. There's a double lipped seal available which seals both ways, and that's probably best. The bottom line though is most of these seals leak. It's a weak design. But with an enclosed primary not many people notice it.
Old Mar 23, 2012 | 07:14 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Did you replace the spacer that runs inside the seal?
Petesharley
EVO
May 4, 2018 10:12 AM
paco
EVO
20
Nov 2, 2013 08:43 AM
superant33
Jul 27, 2010 05:18 AM
SirEagle
Shovelhead
May 28, 2008 07:01 PM
RICHE
EVO
Oct 10, 2007 10:14 AM
