Sponsored by: Jekill and Hyde
Time to upgrade a bit.....
Old 01-27-2011, 08:35 PM
tootal's Avatar
tootal
tootal is offline
Originally Posted by djl
The CV carb is fine, just need to rejet. Going from the BSLs to true duals is like jumping from the frying pan to the fire. TDs wll hurt your bottom end on a 95" build, they are better suited for 107" and larger builds. Look at some dyon sheets and you will see the low end torque dip. Take a look at the 2:1 systems with ghost pipes; D&D and Thunderheader both offer them and there may be others.
On the CV I would recommend a .040" shim under the stock needle instead of the 88 sportster needle. I say this because I have a wide band O2 sensor and gauge set up on my Road Glide. I can see what's heppening while I ride and the sportster needle is too rich. It will run fine, especially when it's cold, but it's really too rich. I found the .040" shim worked well along with a 42 slow speed jet. For the record I'm at 600' above sea level. Now this only works if your intake seals are not leaking at all! After fighting intake leaks for a whole Summer I designed my own and they work great! I hope to put them on the market some time this year.
As for the exhaust I too highly recommend a 2:1. I have experience with the Bassani Road Rage, (loud), and the Supertrapp. (loud as you want it to be, or not). Both of these wake up the low end.
As far as cams, as mentioned I like the 21's but if you use the .030" head gasket and the 26's w/ 9:1 flat tops, I agree that's also a good combo. I only suggested the 21's because of the two up riding. Sound like your ready to go have fun!
Old 01-28-2011, 06:28 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
Originally Posted by Dustmaker
Scott, I got the list finally....lol
Thanks!!
Glad it finally made it over to you!!
BTW, as said, that OE CV carb will work just fine for your build.
If you send it, we'll base-line jet it for you.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
fireaxxe
02-02-2011 06:08 AM
Dyna_in_the_works
11-17-2010 10:33 AM
HD Renegade
04-16-2009 04:01 PM
PJF
18
12-19-2007 12:59 PM
Native American
08-04-2007 02:16 AM
Quick Reply: Time to upgrade a bit.....
