I need more pressure???
Old Feb 1, 2011 | 11:12 AM
fireaxxe's Avatar
fireaxxe
Default I need more pressure???
How do I go from 9.2:1 to 10:1 compression on a stock 96 inched motor. I am thinking thinner head gaskets but wondering what are the options for thickness and what compression will that get me. I see that HD sells .030" shorter and longer push rods, but cant find where they have thinner gaskets, not sure if this is even possible, looking for the easiest way or a set of good inexpensive bolt on heads that will get me there. I am planning to use the SE204 cams and I want to match the compression with the overlap.
Old Feb 1, 2011 | 11:24 AM
ohioflhs's Avatar
ohioflhs
On my 2008 FLHTC, I used cometic 0.030" thick head gaskets and had a local machine shop take off 0.040" from the heads. I think I am around 9.7:1 compression ratio. The bike does not hesitate when cranking with no compression releases. I guess I could have taken another 0.010" off the heads but I couldn't figure out if everyone is talking about static or dynamic compression ratio so I went conservatively and took off 0.040".
Old Feb 1, 2011 | 12:12 PM
fireaxxe's Avatar
fireaxxe
Thanks a great deal man. I think the math they are using is talking about the static compression ratio. You would have a different dynamic compression ratio depending on the heads, cam, even exhaust. Do you know what the thickness is for the stock gasket. And also what type of pushrods did you end up going with.
Old Feb 1, 2011 | 12:39 PM
inverse121's Avatar
inverse121
More pressure or more compression?
You think you wanna run 10:1 with SE 204s? I don't think you do, but I am a little conservative.
Without telling us more about your bike, its hard to know what you'll need to do, but I am guessing from your questions, you need a little help.
Here is a calculator that will help you
http://www.bigboyzheadporting.com/TwinCamComp.htm
9.6:1 is where many like to run the SE204, it still gives you a little wiggle room for bad gas. You might be able to get away with up to 9.8:1 with the right heads.
If it was me, I would call Kevin at ProTwin and get a set of cometic .027 head gaskets and call it good, if you wanted to be a little less conservative, you could run the cometic .018 head gaskets for 9.7:1 CR. You could grind a squish groove in if you think they make a difference.
On a stock 96" motor to get to 10:1, you will get your heads CC'd and millled to 80.5CCs and run a .030 head gasket. You will likely mill somewhere between .025 and .030 off your heads if they are 86CC heads.
I would personally use adjustable pushrods, but you could use the perfect fit if you wanted.
Old Feb 1, 2011 | 12:55 PM
fireaxxe's Avatar
fireaxxe
I guess I should have asked that first, I am looking for the best compression for the 204 cams. My bike is a 2009 Road Kind with a stock 96 inched motor. It looks like your saying 9.6:1 is where I want to be with these cams. I will look up those head gaskets. I am wondering if the valvetrain geometry with the .027 gaskets will allow me to run the stock pushrods, if not which perfect fit ones do I need. I do not want the adjustable ones just a preference. They are heavier and may come loose at the higher rpms, I also notice that everyone that has them have problems getting the correct adjustment
Old Feb 1, 2011 | 01:27 PM
inverse121's Avatar
inverse121
I understand your preference and I am going to give you my $.02.
Anyone that is having problems with adjustable pushrods is not installing them correctly.
The moderate weight difference is irrelevant, they will not back off if installed correctly and I agree, it seems a lot of people on this forum are having problems installing them correctly for whatever reason. I suspect after reading a couple of the threads, they don't know what they are doing. If you need help, I'm about an 1.5 hours away from you.
The "perfect fit" pushrods are not a perfect fit for either one of my suggestions above. You could probably use the -.030" pushrods with the .018 head gasket.
If you are determined to use the perfect fit pushrods for the SE-204, get a .030 head gasket and have .015 milled off your heads. Should give you about 9.7:1 and 190 lbs compression.
Old Feb 1, 2011 | 06:16 PM
redhwk44's Avatar
redhwk44
I have to agree with Inverse as far as the adjustable pushrods go. I did a lot of research on them and when I put in my TW-6-6 cams I chose the SE adjustables and have not had a single issue with them. I say "fear not the adjustables".
Old Feb 1, 2011 | 06:30 PM
fireaxxe's Avatar
fireaxxe
Thanks, I may have to take u up on that once I get everything I need to throw in the cams
Old Feb 2, 2011 | 06:08 AM
myxcape's Avatar
myxcape
I have a 2011 FLHX with the 103" Power Pack option. Considering a set of cams and a .030
cometic gasket. Please let me know what you think about this idea.
Thanks
12, Bob Street
Exhaust System Topics
Apr 16, 2017 06:57 PM
swensos
EVO
Mar 25, 2011 09:29 AM
Night Hog
Feb 5, 2010 02:09 PM
softail99custom
EVO
Jan 21, 2010 08:45 AM
BUSTERK
Aug 7, 2008 02:44 PM
