EFI Fuel Leak
EFI Fuel Leak
Yesterday, shortly after I headed out on my EFI 2003 Heritage, I started smelling fuel and looked down and saw that gas was shooting out from under the gas tank all over my right pants leg. I immediately pulled over as the engine sputtered out. The gas started steaming on the hot engine and I was worried for a time that the bike was going to burst into flames. Luckily it didn’t, but there I was stranded on the side of the road. A few righteous riders stopped to assist and I took a ride back to my house to get some tools. When I got back to the bike, I turned it on again to see where the fuel was actually coming from and amazingly nothing was coming out! It seemed OK. So I quickly started riding it home and once it warmed up again, fuel began shooting out from both sides of the bike now, under high presure even worse then before.
Well, the good news is that I was able to get the bike home and cleaned up. The bad news is that I sure as hell don't know what to do now as I cannot ride it to the dealer and I do not have a hitch on my car to rent a trailer. Any suggestions would be greatly appreciated.
Sounds like a bad hose. Check the crossover hose that is visible under the tank. It connects the left and right sides of the tank. They are known to go bad. Biggest pain with it is draining the tank. If you think you want to DIY, there is good info. hear on how to do it. Just do a search. Once this is done, pretty easy to cut the old clamps off and replace it. You can use worm clamps instead of the factory crimp on ones.
worm clamp=hose clamp
The cheap clamps that you turn screw and it tightens..newer fuel injection clamps if available are nicer and cost maybe a buck more...but cross over line in front of tank is not under pressure..consider purchase of Harley service book for about $50...it will pay for itself in just one repair or service...
This happened to me last month. The one button Ray connector cracked. Never found a replacement so I simply used an old fashioned hose clamp. Mine was a 7.89 for my "07 softie.
Here is the mfg picture of the connector. Once you disconnect from the tank reach in there (tight) and while pushing the button remove the connector and hose from the EFI stainless intake tube.
http://partsfinder.onlinemicrofiche....=13&A=337&B=10
It could be item #15 the quick coupler from the tank. you have to click fuel tank assy to get to the pic im refrencing.
