Sponsored by: Jekill and Hyde
Barnet clutch spring install
Old 07-30-2012, 02:34 PM
jurgie's Avatar
jurgie
jurgie is offline
Default Barnet clutch spring install
I have to install heavy duty clutch spring on my 05 king . Do I need to pull primary cover and the entire clutch pak or can I pull the clutch cover and pull bolts out of diaphragm spring retainer and change the spring out.Tricks and Ideas are welcome by all. thanks jeff
Old 07-31-2012, 01:39 AM
jcb1975@yahoo.com's Avatar
jcb1975@yahoo.com
jcb1975@yahoo.com is offline
Installed that spring on my 99 t/c ultra this past April. I was able to get the old one out, but after about 10 minutes of trying to get the new one in, I gave up and pulled the primary. Not that big of a deal to pull primary, and I was able to re-use the old gasket. When I removed gasket (carefully) I had a pan of water ready and let the gasket soak while changing the spring and adjusting the primary chain. Only trick I can think of that might help you get the new spring in without removing primary is to put the spring in the freezer over night. This might make it contract enough, but not sure.
Good luck.
BlackMarshmallow
01-20-2015 07:10 PM
Brick0044
05-18-2013 11:04 AM
SE120RG
06-02-2009 08:28 PM
DGlide04
12-02-2007 07:22 AM
03 Softail
09-15-2007 11:22 AM
Quick Reply: Barnet clutch spring install
