engine swap
Old Aug 28, 2012 | 07:47 PM
wafflehousepimp's Avatar
wafflehousepimp
Stage III
Default engine swap
hello, i have a friend thats selling his 110 engine out of his 2012 cvo street glide. my question is will it fit in a 2007 street glide? If so whats needed to pull off this engine swap? thanks
Old Jul 13, 2013 | 11:57 AM
Morit's Avatar
Morit
Stage I
Archeorogical bump
Got exactly the same question..
Old Jul 17, 2013 | 01:26 PM
grbrown's Avatar
grbrown
I see you are not getting any help on this one! Not many HDF members call in here, so I suggest you call in the Touring section, where you should get a quicker reply. Assuming the 07 is a TC96 I cannot think of any reason why it shouldn't work, but I haven't done it.
Old Jul 17, 2013 | 02:11 PM
djl's Avatar
djl
Not sure if it will bolt in. The upper mount changed in '08; bolted to the cylinder head but that shouldn't be an issue if you change the whole mount from frame to head. However, the lower mount changed with the new frame in '09; two bolts in it instead of one; this could be a problem.
lordgrape
Engine Mechanical Topics
Apr 10, 2018 04:41 AM
hardheaded
Jun 11, 2016 09:18 PM
dwolfe56
Feb 29, 2016 04:05 PM
wafflehousepimp
Screamin Eagle CVO Models
Aug 28, 2012 07:28 PM
bittysmom
Jun 6, 2010 08:39 PM
