Engine alignment question???
Old May 31, 2010 | 07:09 AM
bittysmom's Avatar
bittysmom
Default Engine alignment question???
Hope this is the right forum...
I replaced the rubber engine mount and now the engine vibrates A LOT! I've loosened and tightened and adjusted...Not sure what else to do. It vibrates at low RPMs but is fine when cruising. Is this the engine out of alignment? Or do y'all have any ideas on what it could be?
TIA
Old Jun 5, 2010 | 04:18 PM
hogbag07's Avatar
hogbag07
The motor could be out of alignment as my 07 left the factory that way. My guess is the engine mount is stiffer giving you more vibes . Give it time and it should loosen up or check out the Search engine above for what other members have used.
Old Jun 5, 2010 | 11:25 PM
tootal's Avatar
tootal
Harley changed to a stiffer rubber I guess to keep the engine from flopping around so bad a idle. I understand getting the part for an old Buell is the answer as they are softer like the original. As far as alignment, I would check every Dresser. I had one RG that was great from the factory but it was totaled. The replacement RG was a mess from the factory. Once dialed in it handled like the old one.
Old Jun 6, 2010 | 07:48 PM
slack20's Avatar
slack20
do ya know the HD no. for the Buell mount thanks.
Old Jun 6, 2010 | 08:39 PM
dogcop727's Avatar
dogcop727
did u start the engine with the mounts loose and let it fall into place. this worked for me. took most of the vibration right out. follow the manual and starting the motor and letting it run for 15 seconds with mounts loose then tighten mounts.
customsoftail200
Jul 1, 2014 08:45 AM
russell6hp
Mar 24, 2010 05:55 AM
Dyna-Asa
Jun 14, 2009 12:42 PM
Yellotang
Sep 18, 2007 09:29 PM
ladodgerdog
Oct 16, 2006 11:00 PM
