Engine size
Let's see if I can get this rite this time , currently ride a 2002road king with1550 conversion mikuni carb striker kit , stroker flywheel 258 cam tc88 perf hds and race enginician system , I'm tying to work out the engine size , been told various from 96"to 113 "
Please help
Please help
Hello old chap and welcome to HDF.
Are you saying you didn't get any service record with your bike?! Do you have any other clues? Because what you describe doesn't compute. It is common to increase the bore of a TC88, which converts it to a 95" or 1550cc and there is an SE kit to do this, which comes with upgraded cams, stronger clutch spring and air cleaner.
However any stroker kit will require different pistons, to allow for the different stroke. You can't have an SE 95" kit AND a stroker kit! Well you could, but if your engine has been stroked it will need a different set of pistons.
If you register your bike on Harley's website (under 'Owners') you will find what your bike started out life as, also you can download an owners manual. You could also talk to your local dealer, to see if they have any service history for your bike. If it was converted by a dealer, that should be recorded.
Hope that helps a bit. Let us know what you find out.
Thanks lads
I have a receipt when I purchased the bike from the dealer that completeted the works , parts are as follows
Mikiuni carb , stroker piston kit , stroker flywheel , 1550 conversion tc88 perf hds b ?? ( £900) 258 cam kit , race ignition and s&s mufflers
Hope this helps more , Andy
Hi Andy, that sounds like entirely Harley stuff. Most likely the crank is the same stroke as a TC96, which along with the 1550 cylinders will give you a 103", as djl suggested. The longer stroke crank is getting into more serious and expensive territory!
So your engine most likely has 3.875" bores and 4.375" stroke, giving 1,691cc. Along with the cylinder heads it sounds as if you have the equivalent of a stage 4 SE kit. Should go like a rocket!
