What to Do?
Old Feb 2, 2010 | 01:49 PM
XParatrooper's Avatar
XParatrooper
Default What to Do?
I have a 2003 lowrider , what is the pros and cons of having the Screaming Eagle "110" kit done to engine.What is the cost and once you go into the engine are you looking for problems later?. Thanks for the help.
Old Feb 2, 2010 | 05:17 PM
Shockcollar's Avatar
Shockcollar
from what i hear, your half way to a new bike when all is said and done...that would turn me off to it
Old Feb 2, 2010 | 08:49 PM
U-234's Avatar
U-234
The 110" kit takes a 96" to 110". To get an 88" to 110" you would have to change the crank. Investigate more. You may just want to go with one of the aftermarket big bore kits.
Old Feb 3, 2010 | 12:34 AM
ZChan's Avatar
ZChan
Most dealers offer the Jims 120 kit to upgrade the 88" engine. I would look into that before the 110" from Harley.
Old Feb 3, 2010 | 12:44 AM
sharkey's Avatar
sharkey
I have an '01 103...you have to split the cases and buy a new crank. On your '03 you'll want to do the Timken upgrade. For more than 103 you also have to open up the spigots and use bigger bore barrels...once you go further than 103, you'll need a heavy duty starter (as well as comp releases) and at least a heavy duty pressure plate. Things will have to be maintained better or there'll be problems. I've got about 30k miles on my 103 (111hp/117tq) and ride somewhat agressivly (why else get the motor?) and we just did a leakdown test and were within spec for a new motor.....
What do you expect to get out of this build??? Speed costs, as they say, how fast do you want to go? Most importantly, you can have fast, reliable, cheap...pick 2.
Old Feb 3, 2010 | 01:51 AM
truckerdave's Avatar
truckerdave
senior experienced all-knowing leader of the unwise
Well my opinion is that you can get 100 rear wheel hp/tq out of just a 95" motor if done right. People do it all the time(i have one). Go ride a 100HP/105TQ dyna and come back and tell me it's not fast enough.
Old Feb 3, 2010 | 03:02 AM
OhioSkully's Avatar
OhioSkully
got a buddy at work that has 100 hp 88cube, he didn't split the cases as far as i know. Did alot of work to it though ill have to talk to him and if its not 100 its dam close cant remember.
Old Feb 3, 2010 | 06:45 AM
red devil's Avatar
red devil
There's no need to go to a 110" motor, 95" is just as good! I've seen some really good 95" builds that are putting out over 100/100. Like sharkey said, your looking at splitting the cases and going with a new crank. Tearing into the bottom end will more than likely double the labor cost compared to going with a 95" build.
Jeffcruz
Nov 27, 2017 12:24 PM
Apostle
Jul 8, 2017 09:11 AM
Zakk13
Engine Mechanical Topics
Apr 16, 2016 07:52 PM
Plow64
EVO
18
Feb 5, 2011 02:06 PM
berryw
Exhaust System Topics
Oct 8, 2005 12:31 AM
