90+ hp/tq build
90+ hp/tq build
i want to push over 90 for both hp and tq out of my 1996 rd king. i have the motor tore down to the cases currently (bent exhaust valve rear cylinder and seeping base gaskets) and looking to do work!! i don't want to go over 10.25:1 compression due to needing to be able to ride in all heat conditions and all over this over corned state of NE (they think corn in your fuel is good...) i need it dependable! im looking for combinations with .010 cylinders, headwork, piston, cam... right down to plugs and wires!!
i do not want a big bore kit, stroker kit, and etc...
any help and dyno numbers would be great!!
more power
getting over 90 t/hp from and evo isn't that difficult. You need a good set of ported heads, correct compression (10.2 is fine) and a good cam, carb and exhaust. I can give you detailed info if you want to write to me. thanks
n2ofaster@charter.net
Rosa's Cycle, in Huntingdon, Long Island tuned one of our(must have built over 75-100 of these over the years) combos not long ago.
S&S E carb Thunderjetted
Our Stage II Evo Heads
Wiseco pistons
Wood #6 cam
Dyna igntion
V&H Big Radius pipes(others would make more)
The dyno report that was faxed over showed 86 hp, and 94 ft/lbs, sae.
This was set at 10.25 cr.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
getting over 90hp out of a 80" evo isn't going to happen with 10.25-1 compression very easily,are you planning on a bar to bar hotrod,or are still planning on touring on it? if you plan on riding it,ide go with a 3.812 bore with your 4.25 stroke.built very mildly you`ll do over 100/110,ideput a carb on it too.(oops,didnt notice it was your build in the previos post,souds like a good build,but it wont make 90/90)
REW13
Engine Mechanical Topics
03-20-2019 03:48 PM
brokeboystreetglide
Exhaust System Topics
35
12-29-2009 05:11 PM
