UL Crank help.
Old Sep 28, 2023 | 09:07 AM
T_levan84's Avatar
T_levan84
Default UL Crank help.
I am having issues getting my crank set up and its keeping me awake at night. I had a set of OEM flywheels and I mocked them up and even with the crank pin nuts semi tight I could not spin the rods, after consulting a very knowledgeable friend he determined that the tapers were most likely worn out. I ordered a new set of T&O wheels and mocked them up to make sure my cases were good to go. I sent the wheels out and had everything balanced and last night I decided to build the wheels in hopes of truing them. Once again when everything is installed I cannot turn the rods with the nuts lightly tightened. I believe that the culprit is the thrust washers, I am using the standard size washers (Vtwin p/n 10-1284, OEM 23972-36) so i dont know why this would be happening. There are no options for thinner washers, only thicker. Im using the correct crank pin for the T&O wheels, I dont have the p/n on me at the moment. Please help! Thank you all in advance.
Old Sep 28, 2023 | 11:21 AM
hellonewman's Avatar
hellonewman
I would wonder about the pin. Is it stepped or not? Do you have a manual to verify the rod width is in spec? I had a lot of challenges with my 41 UH crank pin (bought 3 or 4 in the end) and getting the combination right.
Old Sep 28, 2023 | 11:24 AM
T_levan84's Avatar
T_levan84
I got this figured out. After taking a look at everything, T&O flywheels come with the thrust washers already installed and I was doubling them up. Now I can true the wheels. Just one of those things i didnt think about. Thanks!
Old Sep 28, 2023 | 04:51 PM
johnjzjz's Avatar
johnjzjz
Looking at the pinion shaft the rear connecting rod is the rear one
install the key way pin in the wheels and torque to spec - a machinist trick for tapers is to use talcum power on the NON keyed pin taper its easier to slide at 80 to 90 pounds when you set it for truing
fergerburger
Shovelhead
16
Sep 4, 2017 03:05 PM
limomike
Apr 29, 2017 04:56 PM
Woodys03
2014-2024 Touring Models
Apr 26, 2016 08:50 AM
hdking13
Dec 4, 2013 09:52 PM
nirschl
Jun 28, 2013 04:19 PM
