Primary chain oiler
Old May 13, 2025 | 03:59 PM
Denovo's Avatar
Denovo
Default Primary chain oiler
Question:
does anyone know what the recommended amount oil drip rate should ?
Old May 14, 2025 | 05:06 AM
eighteight's Avatar
eighteight
I suspect "Shop Dope" has the correct rate
If it leaves a small puddle after you stand it up straight it`s probably close enough.
Perhaps @johnjzjz or @hellonewman will weigh in
Old May 14, 2025 | 05:52 AM
Architect's Avatar
Architect
Remove the inspection cover from the primary, leave it on the bench. Warm the bike up good, go for a 10 minute ride. Then with the bike still running and a flashlight, watch how many drips you get in one minute. 1-2 drips per minute will keep you lubed up, more than that will make a mess. Less is bad. Remove the small washers/shims as needed to adjust flow. More shims, more flow, less shims, less flow. Not rocket science at all, just some time and patience. Good luck.
1340fxrt
FXR Models
May 17, 2024 06:08 AM
Crashrdking01
2014-2024 Touring Models
23
Aug 22, 2022 08:32 AM
DavidStiebel
Nov 25, 2015 08:57 AM
GoCards82
Jun 25, 2011 12:09 AM
steveh326
Jan 27, 2008 05:48 PM
