WL idler shaft
Old Oct 30, 2013 | 03:22 PM
Jim Hay's Avatar
Jim Hay
Stage IV
Default WL idler shaft
I'm rebuilding a 48 WL. The generator idler shaft is worn and I have a replacement. Can't figure out how to remove the old shaft from engine case. I've removed the center screw but it's still pretty tight. Any ideas? Thanks.
Old Oct 30, 2013 | 06:11 PM
johnjzjz's Avatar
johnjzjz
we use a snap on tool - its a pin puller, it has a coller that tightens on the pin and a slide hammer to pop it out - we see them come in the shop after using vise grips or what ever and the boss is cracked NOW its a costly fix
borrow the tool from some one or have a real shop remove it for you It does go in much easyer -- johnjzjz
Old Nov 3, 2013 | 08:08 PM
Jim Hay's Avatar
Jim Hay
Stage IV
Thanks johnjzjz, I wasn't sure if the shaft was a press fit or threaded. When I measured the OD of the shaft and the ID of the gear I get .0025 difference. Now I'm wondering if I should replace it or just let it go.
Old Nov 3, 2013 | 08:18 PM
johnjzjz's Avatar
johnjzjz
its a feel for thing - if it feels loose than go for it if it feels snug than i would leave it alone - but it has only one bushing and its easy to swap out , we use bushings from eastern USA made, the china stuff is all over the place in sizing from v twin / the post has a screw in the center that has to be removed first
westnash
2014-2024 Touring Models
Sep 2, 2014 06:25 AM
mattVA
Nov 2, 2013 08:20 AM
BungoBill
EVO
15
Oct 28, 2013 06:14 PM
d_slat
Shovelhead
14
Sep 21, 2008 04:32 PM
