I am having a problem locating the fuel pump relay as well as the ECM relay. The reason being my fule pump stopped working, therefore I assumed it was the original (1997)fuel pump and I replaced it. However, when I was all ready to try and start the bike, the same thing happened turned key and no pumping. Checked all connections and fuses, the only things I can't seem to find on the bike are the fuel pump relay and the ECM relay. Under the right side cover is the ECM unit with a compartment that has 2 fuses labled 15 amp & 5 amp. I am, again, assuming they are fuses to the aforementioned items I am trying to locate, which indicates to me that they are there somewhere if there are fuses for them. Under the left side cover is a fuse block with 4-5 fuses which I replaced the blown ones. So can I get some sort of direction on where to find these 2 items, and maybe a description of same, maybe I'm looking right at it!
