Springs for Sportsters
Ok my 1200L comes with shocks that measure 11.5" just sitting still, so I assume 12" when uncompressed. I don't have a bike jack yet, so I can only guess.
looking for a little more travel and hopefully better ride, so wondering if anything like a 14" progressive shock will work. Bike is a 2007. I have read a 13" is doable, and that rigid mount sportsters can use even longer ones. So are 14" doable? Would I have to change anything else on the bike for it to work?
Worst case I will look for 13's but still wondering.
Before doing anything check your forks. But first let me tell you my experience. I have a XL883L, or SuperLow, bought new. Ride comfort was pretty bad, so I went over it with a fine-tooth comb. What I found was that my forks sagged over half of their total travel - I even had the dealer strip and check them over under warranty. I have since installed single-rate fork springs, set sag correct at 1/3rd travel and the front of my bike is now around an inch higher. I also have new longer shocks a little over 13", so my bike sits level and rides a little higher - a Super-not-so-Low!
I don't recommend using really long shocks, in fact don't see any reason to do so. If you want improved ride quality then buy yourself improved quality shocks.
Take a look at the suspension reports by HDF sponsor DK Customs. They don't cover all brands by any means, but do give some good guidance and recommendations - may even give members a discount!
