I have a 2018 Road King. While they bike handles great in the curves, the factory "hand adjustable" shocks are just too stiff for me. I feel every little bump in the road and frankly it's killing my back. I have tried going up and down to different spots in the preload range and find that doesn't help a whole lot. At this point I just want a nice soft ride. Any recommendations on what rear shocks to change to?
I was looking at the Progressive 444s. Anyone have them? How do they ride? Not set on the Progressives, was just looking at them. I really don't want to spend $600 to $1000 on shocks and not see any improvement. That's why I'm looking for opinions.
You may or may not get what you are looking for off the shelf. What is your total weight? There are quite a few aftermarket brands out there that give a much improved ride over stock for around the $500 mark. You can do a search and read until you're totally confused.
My only caution is that it sounds like you may be one of the special cases that require a much lighter spring rate than most. Most of us middle aged riders are a little heavier than average and are passengers are not underwear models so the aftermarket and Harley for that matter have the nominal spring rates set for the heavier loads. You might want to call around to see about getting some set up custom for you. I know a few of the women on here that have had to do that and are glad they did.
Many people have had the same trouble, with threads about it going back years. Ultimately you get what you pay for. If your decision is based on a particular price point, it may or may not be an acceptable ride quality, but if it isnt youll spend even more money on a second set. Google is your friend, you can find all kinds of opinions about the Progressive shocks as well as many others.
I have a 2018 FLHTKL and am in the same position as you. I have been looking for months at different brands: Ohlins, Progressive, ETC and it is hard to make a decision. For my bike, it has short shocks( I think 11") so I may try 13" HD premium shocks if I can find some take offs. Longer shocks = more travel in the suspension and softer ride. The re-bound, sag setting, and spring size are critical for your weight. If you are riding 2 up, she will feel the rear shocks more than you because you are balanced between front and rear, she sits directly over the rear shocks.
Longer shocks don't necessarily equate to a softer ride. Longer shocks give you the travel to absorb bigger bumps, but spring rate is ultimately what will give you a soft ride. If you put stiff springs on a long shock it's still going to be a rough ride for a lighter weight person.
Some things for the OP to consider...It may take a bit for the springs to break in, so to speak. If you don't have a thousand miles or so you may want to wait on swapping them out. If you are outside of the normal weight range (light or heavy) having shocks with springs selected for your final riding weight would be a good choice. Howard at Motor Cycle Metal can hook you up with custom built shocks based on Ohlins.
My 17 RGS took a while to dial in as I weigh in at 180. I backed the adjustment down all the way, rode it for a while and found going up just a couple clicks is where the sweet spot is for me.
I did however finally put a set of Progressive 430's on my Road King and the improvement was drastic. But we are talking totally different animals.
I thought the new bikes had great suspension over the last generation, I guess not. Anyway good shocks start about $500 and go up from there. I think Ohlins may be the best but are a bit more money. Super shox, Bitubos and Pro action have good reviews and are also built to your soecifications. I will probably be going with one of those three myself.
