1976 FLH front brake lever falls to bar if I grab it SLOWLY
Howdy all,
These forums have been great for my newer bikes so I thought I'd give y'all a holler for my first Harley, my 1976 FLH. I live in a rural area and the only shop around here that works on Harleys is the dealership over in Danville, and they ain't exactly gung ho on servicing Shovelheads. Old Rocket Roger passed away a few years ago and he was the only one I knew of in the area that new these older bikes.
The issue I have is the front brake lever will fall to the bar if I grab it SLOWLY. If I yank on it hard the brake will grab and hold and the lever holds steady until I ease off pressure. If I do slowly ease up on it and pull it again it will fall towards the handlebar. I have bled the system and the problem crept back in. Up until recently the system has worked flawlessly.
I'll give y'all as much information as I can about the components of the brake system. The lines are braided stainless steel and the caliper is GMA. Here is a pic of the caliper:
Here is a pic of the front master cylinder:
I THINK it may be a Drag Specialties unit like this:
Drag Specialties Master Cylinder Assembly 3/4 in. Bore Dual Disc - DS-290708
but I cannot say for sure, it has been on the bike many years.
There is no brake fluid leaking anywhere in the system that I can find. I replaced the master cylinder gasket when I last bled the brakes a couple of months ago. The system has always had DOT 5 brake fluid in it to my knowledge.
Given the strange behavior of holding when I grab the lever quickly does anyone have any ideas as to what to try next? I'm not against replacing the master cylinder if necessary but I thought I should put this scenario out there for folks more knowledgeable than myself to consider.
Thanks in advance for any and all ideas.
Received 17,598 Likes
Hoyt 1911A1 (02-09-2019)
the master piston cup is by-passing fluid. when you apply quickly, the quick build in pressure expands the cup and it seals to the bore but when applied gently, it does not flare out tightly and leaks around the lip.
hopefully, the bore will be "OK" and a repair kit is all that is needed.
https://i.ebayimg.com/images/g/r8oAA...YbO/s-l300.jpg
Kingglide549 (02-09-2019)
Received 47,791 Likes
six_strng_slnger
Shovelhead
13
08-09-2014 11:31 AM
