Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Holy Frigg'n Crap!
Old 06-12-2019, 05:19 PM
Stinger1's Avatar
Stinger1
Stinger1 is offline
Default Holy Frigg'n Crap!
Wanted to put a new chrome kickstand spring on my 09' FLSTF.
Watched the YOUTUBE videos and saw how easy it was. Remove a bolt, let the stand slide forward relieving the spring pressure and install the new spring, reverse procedure. Easy enough.
Ohhhhhhhhhhh Nooooooooooooooo. Mine doesn't have a bolt. Mine has a 5/16" pin and a retaining clip and 2 bushings, one upper and one lower. That thing kicked my ***. There is no way possible to simply remove the spring and re-install, the spring is way too stiff.
I would honestly rather replace my crankshaft than go through that again. If I ever have to do it again, is there an easy way of doing it?
soldierbot (06-12-2019)
Old 06-12-2019, 05:24 PM
Kawickrice's Avatar
Kawickrice
Kawickrice is offline
Received 3,255 Likes on 1,518 Posts
It's amazing how a little task can eat your lunch sometimes. You would rather replace the crank huh?
Old 06-12-2019, 06:15 PM
Mountainkowboy's Avatar
Mountainkowboy
Mountainkowboy is offline
Had to replace one on my 89 that broke, used a brake spoon with the stand up, was easier than I expected, but still a PITA.
Old 06-13-2019, 08:10 AM
bustert's Avatar
bustert
bustert is offline
they make pliers for that.
TwiZted Biker (06-13-2019)
Old 06-13-2019, 08:18 AM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 48,246 Likes on 17,596 Posts
Don't know what the newer kickstands look like but the older softtail & FL series I just take the locking cam off the top and push the stand forward till the mount tabs are closer together, otherwise that spring can whip your *** when new.
Old 06-13-2019, 11:06 AM
smitty901's Avatar
smitty901
smitty901 is offline
Received 9,770 Likes on 5,255 Posts
Ever done a brake job on older drum brake cars and truck.
cprhed (06-13-2019)
Old 06-13-2019, 11:36 AM
Since 1968's Avatar
Since 1968
Since 1968 is offline
One thing that helped on brit bikes from the 60's and 70's was to insert a coin or thicker spacer in between each coil of the spring so the whole thing is temporarily stretched longer. No idea if there is clearance to do this on your bike, but certainly worth a try at no cost...... Hopefully it's going to be a long time before you ever have to try it again.
Old 06-16-2019, 09:57 AM
Stinger1's Avatar
Stinger1
Stinger1 is offline
I actually tried that using washers. I couldn't get the spring to uncoil far enough to insert the washers.
And yes I have replaced many drum brakes over the years, I'm approaching 60, so yea, been there done that.
Chris7426
05-31-2019 10:34 PM
shagnasty
08-24-2018 07:54 AM
Principle
General Topics/Tech Tips
03-20-2016 06:25 AM
CoachJR
06-24-2014 02:06 PM
paulies 07
01-25-2013 07:44 PM
Quick Reply: Holy Frigg'n Crap!
