Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Suicide shifter conversion
Old Mar 30, 2005 | 12:55 AM
Lovetoride's Avatar
Lovetoride
Default RE: Suicide shifter conversion
ORIGINAL: pococj
LOL, it's just 'cause my Mommy made me learn to read.
Sounds like you have a good mom bro...
Thanks again for all you do Skip...
Ryan
Old Mar 30, 2005 | 10:07 PM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
Go Skip,
I've ridden my buddie's Four Cylinder Indian and numerous Knuckles and Pans with Suicide clutch with tank shift. They were a ball but then again I wasn't running like a bat out of hell like the new bikes. Do they look cool-hell yes-ask Jesse James. Would I want to roll up to a stop sign on a hill on my Roadglide with both feet on the floorboards and my thumb up my ***. I don't think so. Remember-you can teach an old dog new tricks, just not a dumb ole dog!!!!!!!!!
Terry
Old Nov 24, 2019 | 08:54 AM
David Ramirez's Avatar
David Ramirez
Stage I
Originally Posted by pococj
First off, let's get the terminology straight. It's a suicide clutch, not a suicide shifter. The shifter part will either be a jockey shifter, where the shift lever is fastened directly to the transmission, or maybe a hand shifter that is mounted to the top engine mount, or the frame. The old bikes had the shift lever mechanism mounted to the left side gas tank. Later ones had it mounted to the left front frame downtube. These were often called police shifters. Transmissions had hand shift (jockey) tops early on, and then came ratchet tops, and finally cowpie trannies. Some were 4 speed, some were 3 speed w/reverse. All 3 speed w/reverse had jockey tops. Then the 5 speeds came and they are all ratchet tops, though no one calls them that.
The suicide clutch operates just like a car clutch; push the pedal down to disengage the clutch, and let it up to start moving. The suicide part comes from when these were run with no front brake. If'n you pulled up to a stop on a hill, didn't get the bike into neutral, you had a problem. Right foot had to be on brake pedal, left on clutch. Oops, fall down, or shoot through the intersection.
Original clutch was a rocker clutch. It stayed where you put it; heel down was disengaged, and toe down was engaged. If the spring was removed or it got out of adjustment, it bacame a suicide clutch. Hopefully not when least expected!
Labriola makes a good suicide/jockey setup for 5 speeds. Hotop makes one that is to be used with a hydraulic clutch, but it isn't a jockey shift. It's a hand shift that replaces the top motor mount. V-Twin has a rocker clutch and frame mount conversion kit, though the quality ain't all that good. I've got the rocker clutch from them on mine, and had several problems, including a broken weld, parts not lining up, and a cable that breaks at least once a year. It's being converted to a hydraulic setup as I write this. I built my own hand shift lever and mounting setup.
I've run a foot clutch and hand shift for about 25 years. Once you get used to it, it becomes second nature. And the stuff about pulling your hand off the bars, well it ain't never been an issue. Ain't ya ever picked yer nose while riding?
If yer bud wants to do it, and has questions, ask 'em. I'll be glad to answer whatever concerns he might have.
Suicides rule; the rest are sissies!
Thank you for sharing I myself would like to convert my 2003 Harley Davidson Fatboy flstf ANNIVERSARY. Could you please tell me what parts I will need and who I can order from. I would really appreciate it if you have the time to share more of your knowledge and experience. I like the idea of making my ride and exploring other options to my taste. Anyway thanks again hope to hear from you again. Ride on.
Old Nov 25, 2019 | 10:56 PM
OLD 96's Avatar
OLD 96
WOW. You went back over 14 years to comment on your first post. Welcome to the Forum from Waco.
Old Jul 10, 2025 | 04:35 PM
Misterskunk's Avatar
Misterskunk
Stage I
very knowledgeable, im determined to do the conversion myself.. my only complaint is that the kits people sell all seem to have generic looking shifters... I believe you're route on fabricating the parts would look the best... on my 09 softail everything is on the left side, with a little fabrication knowledge I feel like it could be done pretty simple, creative and effectively.. do you have any pics (😋 if you're willing to) of you setup you could show?
Old Jul 10, 2025 | 06:02 PM
Addicted to Chaos's Avatar
Addicted to Chaos
Captnpirate
2014-2024 Touring Models
Aug 15, 2017 03:49 PM
latnyte
Sep 28, 2009 06:48 PM
Carolina Fatboy
Apr 23, 2008 02:00 AM
hotpursuit
Oct 4, 2007 08:40 AM
Cowracer
Jun 7, 2006 01:57 PM
