Recently got a 1984 FXRP It has a mechanical speedo mounted on bars. I want to put taller risers on it. can I get a longer cable or is there a way to put a newer electronic speedo on it?
Thanks
Jeff
Thanks
Jeff
You can get a longer cable. You need a late style transmission with a speed sensor built into it to be able to run an electronic speedometer.
