FXR Models Discuss the FXR Models in here
vibrations
Old Jul 22, 2023 | 10:42 AM
jyx's Avatar
jyx
Default vibrations
So i have this vibration issue with my -93, so far i have changed wheels and tyres, front and rear motormount´s, cleve blocks and stabo links. it is worst from 45 and slower mostly in footpegs and seat over that it kind of gets better but i would like to go slow some times to have a chance to smell the flowers what else do you think i should look for ?
Old Jul 22, 2023 | 03:55 PM
byrdman.45's Avatar
byrdman.45
Possible exhaust hitting frame, heat shields loose or clamp touching somewhere?
Old Jul 23, 2023 | 02:09 AM
jyx's Avatar
jyx
Thank´s for your replay but nope, checked all that too,
Old Jul 23, 2023 | 05:46 PM
Redrodyankneck's Avatar
Redrodyankneck
Did you check the steering neck bearings?
Old Jul 26, 2023 | 02:31 AM
jyx's Avatar
jyx
yes i did, the vibrations is worst in the footpeg and seat area if that gives any clue.
Old Jul 26, 2023 | 07:15 AM
Redrodyankneck
Certainly sounds like something to do with the wheels, tires. Did you change out the bearings and races with the new wheels? Did you set/check wheel end play?
Old Jul 28, 2023 | 11:49 AM
jyx's Avatar
jyx
not on the wheels that are on now but did change the bearings on my spoked wheels and the mag wheels that are on know worked perfekt on the sportster i stole them from, no difference if i swttch back and forth whit the weels i have.
Cootey
May 30, 2023 04:40 PM
Mithion
Aug 20, 2014 10:06 AM
HD Bobber
Exhaust System Topics
Dec 17, 2013 12:10 PM
Dynaunder
Dyna Parts
Jan 23, 2013 01:57 PM
Crazycoop
Nov 15, 2007 07:46 PM
