I have a 2007 Nightster that has a little over 3,600 miles on it. The other day my rear brake stopped working. It was working just fine the last time I road it about two weeks ago. I don't see any leaks in the line but there is zero pressure. I press on the brake and I get nothing not even the brake light. Where do I need to start looking?
Did you check to see if there is any fluid in the master cylinder? If not, then you've definitely got a leak. If it's full then I would suspect the master cylinder has failed. Even if there is air in the line you should get some braking with a spongy feeling pedal.
if i'm not mistaken the brake switch is a pressure switch and is in the hydraulic line. if the reservoir is full, tar snake is probably right. rotted/ broken seals due to lack of use.
