hello from whistler b.c. w/questions
well...name is stew, and completely new to this harley seen,,, hope to meet some cool people and learn about my new 04 heritage classic softail,,,, i have mastered the japanese bikes,,,, drag racing at 7.7 sec 1/4 mile,,, so now to figure out this new puppy,,,, any info is more then wellcome,,,,questions
oils? 3 differant kinds
engine oil, is in the side contaner,, that feeds just the engine,, red line 20w50,,,
any luck with castrol 20w50????? or royal purple???
primary,,, clutch and ????what to use in here,,, same as above??????
trany,,, ????ATF ???? what to use in here,,,,,says to only use harley brand oils,,, but would like your thoughts??????
has rineheart short pipes,,, so thinking it might have a stage 1,,,
with the chip,,,any way to tell,,,thx for your thoughts
Received 6,045 Likes
Received 8,259 Likes
Welcome from Spartan Country Michigan!!! search the forum and you'll find plenty about oils. Everyone has a favorite, and you will be wrong with whatever brand/type you choose!!! I recommend you get a three ring binder or notebook and record everything you do, service, repairs, accessories, etc. you will appreciate this down the road. Perhaps the best tool you can buy are the factory service manual and the parts manual. Much info in there. And be prepared for a bunch of comments, offensive and defensive from this joint! Many good people here!!!
Hello from the other end of the Duffy!
You'll probably get 50 different opinions here, but I just use what's in the owners manual because that's what it calls for. Seems like plenty of guys use Amsoil and swear by it.
If oil made that much of a difference there'd be a consensus on it, in my opinion.
Welcome from Michigan!!!
I'd be comfortable using any brand name of 20w-50w synthetic oil as long as it has the V-Twin additive as long as you change the oil at 5,000 mile intervals (or less).
The BIG issue with the early T/C engines is the cam chain tensioners.
If you don't know the history of your bike and if it has 20,000+ miles on the odometer you should at least have them checked or replaced.
Some people have had tensioners break part at 25,000 miles but others have lasted much longer.
If these tensioners bread apart the fragments can block oil passages and can (and have) caused serious (as in ruined) an engine.
You can go three different ways on these tensioners:
1. Use OEM tensioners
2. Install S/E Hyd. Cam chain adjuster kit with H.O. oil pump.
3. Consider converting to a gear-to-gear set up (engine noise would increase).
Between me and the wife, we have owned 5 Heritage Softails:
A '92, a '95, a '88 Heritage Springer-still have), a '99, and an '08 (still have) and all were reliable machines.
Enjoy your bike and you sure have some beautiful scenery up your way.
