Oil filter differences
Old Mar 30, 2019 | 07:18 AM
shanneba's Avatar
shanneba
The HD 5 micron filter has synthetic media.
Synthetic media can have improved oil flow compared to a cellulose filter media.
A good overview of Oil Filtration, part 2 is about filter media:
Basics of Filtration
Synthetic vs. Cellulose Media and Usage in Liquid Filtration
There is more area for fluid flow in synthetic media than the Cellulose Media.
As these media are loaded with contaminant, we see another advantage of the synthetic media increased flow area.
Contaminant that plugs up 50% of the cellulose media surface area will only plug 10% of the synthetic media area.
The result is much lower restriction in the synthetic media when compared to cellulose media for the same level of loading.
A molecule of oil is on the order of a thousand times smaller than one micron.
Cold oil molecules are actually slightly smaller than hot oil due to the Viscosity Index Improvers.
A Simple Explanation of Viscosity Index Improvers
If the filter does produce an increase in resistance to oil flow, the oil pressure will increase but the oil pump will still move the same volume of oil every revolution.
The HD oil pumps are positive displacement oil pumps.
Synthetic oil filter media
Old Mar 30, 2019 | 09:39 AM
tar_snake's Avatar
tar_snake
Originally Posted by soldierbot
I picked up one of these several years back. No more paper filters to deal with and the product works great.
https://www.amazon.com/Engineering-F.../dp/B01BKWQGZ4
K&P Engineering hit it out of the park with this oil filter. I found out about them in 2010, I think it was, and hated to spend the money they wanted for one, but after figuring it up how much I'd spend the rest of my years on bikes, this was the *ONLY* smart way to go. It paid for itself while I owned my '09 (bought the filter in '10), and before selling the '09 I took it off that bike so that I'd have it for my current '98. Beats throwing away filters every 2500 miles (when I do my oil changes, religiously), doesn't dump all over the front motor mount but maybe a quarter of the amount of oil that a standard oil filter does when I change the oil, is easy to clean in the extreme. Just order two or three replacement o-rings for the seal and maybe even a second filter remover cap for it, just in case you move a lot (like me, unfortunately) and happen to lose one. I didn't need to change the first, original o-ring until two oil changes ago, by the way.
Old Mar 30, 2019 | 11:16 AM
LQQK_OUT's Avatar
LQQK_OUT
Originally Posted by RHPAW
If you put a twinkie oil filter on an Evo, it restricts the flow because Evo filters are 10 micron and twinkies are 5 micron.
If you get an Evo filter from the dealer these days, you have to get a Sportster one (still 10 micron)..
You can put a Evo filter on a twinkie, but it won't filter as efficiently.
According to HD, these can be used in an EVO. It says the following in the Harley-Davidson Genuine Motor Parts & Accessories Catalog.
HD Part Number: 63798-99A
"can be used as an upgrade for any motorcycle that requires Oil Filter P/N 63796-77A, 63805-80A, 63812-90 or 63813-90."
Old Mar 31, 2019 | 07:33 AM
1004ron's Avatar
1004ron
Wix has a good reputation, but I will stick with H-D filters.
The H-D filter tool is too large for the Wix filters, so just be prepared for that if you plan on trying the Wix.
Old Apr 1, 2019 | 10:42 PM
Zerk's Avatar
Zerk
I used HD cause when I used an after market with the oil cooler, it was just a tiny it to long. Would not spin on. I tried spinning it on, over and over gain, got the old one ad went out. It was hitting CPK by a hair.
Though somedaymaybe will try again. Not cause money, but because fleet farm is open later than dealer.
shamis
Mar 20, 2013 08:43 PM
blackbear
EVO
Aug 21, 2012 08:16 PM
getty30188
Oil Archive (no new posts)
Jun 19, 2011 04:44 PM
20King05
Mar 30, 2010 11:00 PM
Lurch42
Jun 24, 2005 04:59 AM
