Back on the road, then this . . .
Greetings!
Long time since I posted. I've posted this in General, assuming that since this pretty generic it should fit? If not, then please move it to the appropriate forum. I have a 2015 Ultra Ltd with a stage one that I installed myself. With life getting in the way, I put my motorcycle up for about a year. Just recently I checked the tires, fluids and etc and rode to the dealership. Had them replace the brake and clutch fluid w/flush and give the bike good checkout etc. Since the bike didn't run for a year, I thought that replacing fluids all 3 holes would be wise - even though I use high quality synthetics. Oil and Transmission went fine - now (which I almost didn't do) on to the Primary/chain case. I was able to drain the chain case and then unscrewed the first 4 of 5 screws on the clutch inspection cover and on the fifth disaster struck. The T25 skipped and somehow that head is screwed up where I cannot loosen it but I can tighten it. I'm using craftsman tools, which have served me well in the past. I'm not sure how I could of screwed this up, but I did. Or maybe the dealership did? Not sure. The one that screwed up is in approximately the 7 o'clock position. I've puzzled over this for more than an hour and have come up with some ways around this problem, none of them good. I have a manual, but I'm trying to keep the solution simple. I need advice on the best way to handle this:
Any other choices that I'm not mentioning here?
Thanks In Advance . . . any advice would be greatly appreciated!
Mark Sanderson
- Remove the chain case cover and attempt to remove the t25 from the access plate from the back end. I've never removed this one before, not sure if I need gaskets . . . can I reuse the gasket at least temporarily? Does the nut extend into the chain case in such a fashion that can back it out easily?
- Use a Ryobi nut/screw removal tool. I've never used one of these before. These are the ones where you drill a small hole into the ruined nut, and then insert this tool which will grip the walls of the drilled bold and then allows you to back it out. Any tips on using these tools? Is there any danger to the chain case cover using this tool?
- Give up, call a wrecker and have the bike towed in and repaired. Boo. I don't want to do this but I will if I must.
Mark Sanderson
markfsanderson (04-28-2019)
All is not lost. First, unless something has changed, those are T27 torx not T25. You may get lucky and have enough meat to tap a T27 in there and get it out. Second, for 25 feet, it wont hurt without fluid. Its splash lubed, so takes minimal fluid anyways. There is enough residual to go that far. Other option is to drill off the head, and attack the rest with vice grips. Once pressure is removed from the body, they normally cooperate. You should change gaskets when disrupting them. Cheap insurance against leaks. Hope this helps
The following 3 users liked this post by ScottinAZ:
The following 4 users liked this post by Screamin beagle:
Campy Roadie (04-29-2019),
Candler (04-29-2019),
markfsanderson (04-28-2019),
Zonktified (04-30-2019)
I have one of those cheap sets from HB. It’s the big set also comes with the security torx bits with the hole in them. Best ten bucks I’ve ever spent
Op: since you only have one bolt left holding the cover you might be able to spin it( the cover) and break the other bolt loose like that. Or you might take a small sharp chisel and hit the head of the bolt counter clock & break it loose that way(carefully). I get lucky sometimes doing this. Good luck
https://www.harborfreight.com/100-pc...ase-62657.html
Save lots of potential future aggravation by slapping yourself every time you think of buying something with 'Ryobi' on it and put what you do have in the bin. Ryobi really is cheap and nasty cr*p. As others have said, if the T27 bit lightly tapped into the screw doesn't work, drill the head off and remove the screw shank with vice grips.
The following 4 users liked this post by dawg:
