Headlight and passing lamps stopped working
Received 5,228 Likes
Just came back from a ride and as I was parking the bike, the headlight and passing lamps suddenly went out. Then after a few seconds, they came back on and then went out again. Then they wouldn't come on at all. Over time, I've occasionally noticed that the headlight would sometimes have a split-second blink or shimmer.
Well, a few minutes ago I went out there, turned the switch, nothing. But then after a few seconds, I heard a sound and the headlight came on. The sound I heard was like a high-pitched "tink!" sound and the headlight would come on, but on high-beam only. On low-beam, I get nothing. When I switch it back to low-beam, there's a "click" and the light goes out.
So anyway, the "tink!" and the "click!" appear to be coming from the main switch. I can hold my ear to the switch, flip the high-low switch to high-beam, and after a few seconds I'll hear the "tink!" and the high-beam will come on. If I switch it back to low-beam, I get the "click!" and the light goes out again.
So what do you think is the problem here? The ignition switch or something else?
Just checked it again with my ear next to the ignition switch. Very audible clicks when I change the position from high to low beam and back. Plus, when I flip it over to high beam, it sits for a few seconds and then "tink!" and the high beam comes on. Flip it back to low beam and it clicks and then no light.
What breaker? Where? I'm not a mechanic and I need some help with this.
Received 5,019 Likes
Dude, you have a short somewhere between the switch and the headlights. A wire has been rubbed to expose the wire, it is randomly hitting something and shorting. It sounds like it is related to fork position, so maybe one of the wires from the gas tank to the front end. Since it is only the lights, should be pretty easy to figure out which wires are in question, do a thorough inspection. When you find the culprit, insulate as needed and carry on.
Windseeker (06-12-2019)
