HELP! UNDER CONSTRUCTION..
I came through the back door to get back onto this site. When I try to go directly to the HD Forums.com/ I keep getting, "Under Construction" I didn't know if there were server problems or what.
Thanks in advance, Bill wmjonesosp295@aol.com
RE: HELP! UNDER CONSTRUCTION..
It happened to me last week, using Firefox. For some reason in my bookmark the www portion was missing. It was hdforums.com which didn't work.
Replace the bookmark/favorite with the www and it should work fine.
I had the same issue at home and work with Firefox 3.0 Beta.
I had to clear my cache and cookies and then it worked fine.
In FireFox, click Tools, then Clear Private Data, check Cache and Cookes, and then click Clear Private Data. Problem should be solved then.
I solved it by coming in through some other page, then going to the home page once here, then replacing my bookmark with that new page. Seems to have solved it. I'm using Firefox also.
I've got this very problem when at work. Bastards in IT!!! [8D]
And now none of my backdoor tricks work either. I can now only access the site here at home. We use IE for the browser at work, so deleting files and cookies and starting from scratch doesn't work.
Thanks for the replies! I thought maybe it wasjust my computer doing a thing of it's own. I will try the above advice and see what happens.
Ok, deleted the cookies and history. Cleared the cache and it seems to be working fine now. Thanks again.
