Blue Burnt Pipes
Blue Burnt Pipes
I bought a new 2008 Harley Davidson Ultra-Classic on March 31, 2008 from Adamec Harley Davidson in Jacksonville, Florida. \\; The engine was bored out to 103 CI, and I appreciate the extra power. \\; However, the heat from the engine and pipes is unbelievable, and the right side chrome muffler pipe \\;is burnt blue near the end of of the muffler. \\; The dealership told me when I bought the bike that since they bore out the engine that they would be responsible for any problems that came up, and I did buy the 5 year extended warranty. \\; When I returned from a road trip around the country I asked the dealership about the discoloration, they said it's normal on some bikes, and suggested I could buy a new chrome cover for it. \\; I'm not sure, but according to some friends the dealership should be responsible for replacing the burnt pipes and for finding a way to cool the engine a little. \\; Any suggestions?
RE: Blue Burnt Pipes
Depending on the amount of blueing, it could be normal or it could be mixed a little lean. \\; The twin cams run hotter than the older big twins did, so that can make it a little more difficult to avoid blueing. \\; Check your fuel mixture though. \\; Did you get it dyno tuned after the engine build? \\; If so, then the mixture ought to be pretty good. \\; If not, then I would reccomend getting a good tune done. \\; If the blueing turns out to be the result of an improper tune, when the dealership was paid to \\;do it, then I'd say you deserve some new pipes.
All Harley Davidson service writers are programmed (from the factory) to say " it ain't covered". Here's a picture of mine. I have the SE a/c and the Harley Stage 1 download, and the bike runs flawlessly, with minimal heat. My plugs (after 10,000 miles) are a light tan, indicating a perfect fuel/air ratio. What heat shields are being refered to?
Character..........yes. I'm going with that also. BTW, I checked the heat shields and found that they do not fit the one piece slip-ons. Typical Harley! If you \\; want the slip-ons that do not discolor, it'll cost ya another c-note.
