mine are always in the garage and I have had no problems with them, over the winter I put them in their box and throw in a dryer sheet ( my Grandmother says they keep mice and bugs away)
...a dryer sheet ( my Grandmother says they keep mice and bugs away)
It does work, as does a bar of soap. I keep soap bars in my stored car, too. Also smells nice.
...you're wearing em in the winter and with the wind chill factor getting down to zero or so.
"Wind chill factor" only affects you, not inanimate objects. i.e. If the temp is 2°F and the wind (or your sriding speed with no wind) is 50mph, you will feel -51.something°, but your helmet will only 'feel' 2°
Not true, windchill will affect any inanimate object that is above ambient temperature. If this weren't the case, air cooled engines wouldn't make any sense, they'd run the same temperature regardless of whether they were standing still or running 70mph down the freeway. Wind cools objects more quickly that are above the ambient temperature than the same objects would cool without wind chill.
Funny, it could be 10 degrees outside or 110 degrees outside and my water cooled bike or cage will hit the same temperature. The Harley, an air cooled bike will still get up to temperature running on the 10 degree day, it just takes longer but is will eventually get there,
Because of the thermostats regulating the temperature on the water cooled engines.
Damn. You got me on a technicality that I forgot. True, wind won't make anything colder than the ambient temperature.
Although, it's technically not wind chill that's cooling, it's actually heat loss by convection.
