Need help...won't start
Old Jul 18, 2009 | 05:45 PM
stro1965's Avatar
stro1965
I can pull the cover but I honestly can't imagine why that would matter. I might as well try though!
Old Jul 18, 2009 | 06:39 PM
tda69's Avatar
tda69
Ground cable. Check the ground. That's probably the problem.
Old Jul 18, 2009 | 08:35 PM
stro1965's Avatar
stro1965
SMALL VICTORY TONIGHT!! I had mistakenly assumed it was getting fuel because I could smell gas when I pulled the plug to check for spark. NOT. A shot of starter fluid into the throttle body and it fired right off. Didn't stay running, of course, but at least I've narrowed it down a bit. Before this ever started I had made an appointment to have the dealer get inside the tank to change the fuel filter (20K service thing), so I'll bet the problem will be pretty obvious once they dig in. I'm done until I load it onto the trailer on Monday. Not gonna switch out ECM's unless they CAN'T find anything wrong in there. Thanks very much for all the suggestions!
Old Jul 19, 2009 | 12:51 AM
4JAYS's Avatar
4JAYS
you didn't accidently bump the petcock to the off position , did ya?
Old Jul 19, 2009 | 05:29 AM
stro1965's Avatar
stro1965
No petcock on my bike.
Old Jul 19, 2009 | 06:18 AM
rockDAWG's Avatar
rockDAWG
Cool, looks like you are making progress. The problem is related to fuel system.
1. When you power on the system. Do you hear the fuel pump start humming for a few seconds? If no, check the power to fuel pump. IF yes, fuel pump is bad.
2. Check for fuel pressure, look for a relieve valve near the fuel regulator, push the pin in you should see gas will squirt out. If no, check fuel line.
HTH and good luck
Old Jul 19, 2009 | 08:46 AM
stro1965's Avatar
stro1965
HTH and good luck
Fuel pump primes up, as normal. Gonna let the dealer handle the rest. I'm tempted to do it myself but I already had the appointment set up and they were gonna do the fuel filter anyway. I'm guessing something came apart inside the tank, a hose came off or something. I'll let ya know what I find out!
Old Jul 19, 2009 | 11:48 AM
rockDAWG's Avatar
rockDAWG
Sounds like a plan, besides it is good for the economy to get money circulating instead of keep under the mattress.
Old Jul 20, 2009 | 07:04 PM
stro1965's Avatar
stro1965
Hauled it in today. Sad seeing my baby on a trailer.
billyg1
Aug 23, 2015 08:13 AM
Village Idiot™
Aug 24, 2014 05:27 PM
speeddemonjb
16
Jan 5, 2012 12:38 PM
02HarleyDJV
Sep 7, 2011 09:12 PM
Weatheredge
Jun 26, 2011 11:46 AM
