Need help...won't start
Old Jul 17, 2009 | 09:03 PM
stro1965's Avatar
stro1965
Default Need help...won't start
2007 Ultra, 20,000 miles, stock except for T-Max, Andrews 26H cams, V&H Propipe and SE A/C.
I got caught in a heavy rainstorm yesterday morning and, when I eventually made it back home, I cleaned it up a little and changed oil in all 3 holes. The only other things I did were replace the rear brake pads and bolt on a chrome voltage regulator. After all of that I ran it around the block a few times and parked it, just to check for leaks. All was well.
Tonight it won't start. Cranks, and has spark, but no start. Fuel pump primes up normally. No T-Max fault codes, loaded a different map and re-initialized, no change. Battery is starting to wear down now.
If something got wet yesterday why would I have been able to start it up several hours later only to find that it won't start today? And if something DID get wet, what is the most likely culprit?
HELP!!!!
Old Jul 18, 2009 | 01:13 AM
4JAYS's Avatar
4JAYS
Got Gas in it?
Old Jul 18, 2009 | 01:50 AM
Sick1200's Avatar
Sick1200
You may have answered your own question with that "battery is wearing down now" statement.
Old Jul 18, 2009 | 04:45 AM
SoALposer's Avatar
SoALposer
When you bolted on the regulator, did you by chance pinch a wire and it finally grounded out when you were taking it around the block.
Just asking.
Mike
Old Jul 18, 2009 | 05:36 AM
stro1965's Avatar
stro1965
Both the battery and the voltage regulator are at the top of my list. The first thing I concentrated on was the voltage regulator, looking very carefully for anything that might have been wrong, found nothing. I'm leaning towards a weak battery, even though it will turn over the engine it's been turning slower lately. It's on a tender all last night and throughout the day today, I'll see if it fires up tonight when I get home from work. If it does, I'll pull the battery for a load test.
Old Jul 18, 2009 | 05:53 AM
tjvrodrick's Avatar
tjvrodrick
Try puting back the old voltage regulator back ??
Make sure the bike has gas
Have fun Ride Safe
Rick From San Diego / TJ Mexico
1992 flhtc
2002 V-Rod
soon to join the 260 club
Brembo Calipers front & rear
AW wheels
Metzelers & Dyna Beads
V-mods
Old Jul 18, 2009 | 06:18 AM
stro1965's Avatar
stro1965
Tank is full and I didn't change the voltage regulator, just put on a chrome cover.
Old Jul 18, 2009 | 08:20 AM
tmitchellof PG's Avatar
tmitchellof PG
Did you take the battery cables off,clean them and tighten them back up properly. There may be a barely loose cable, that allowed some corrosion and the rain damped out the connection.
Tom
Old Jul 18, 2009 | 09:05 AM
stro1965's Avatar
stro1965
Tom
No, but I did try to move the connections and couldn't, they seemed tight.
Old Jul 18, 2009 | 09:39 AM
rockDAWG's Avatar
rockDAWG
It sounds like moisture got into the ignition system. USe WD 40 to spray all electrical contacts, I think this will do the trick. Good luck.
IF this does not work:
1. Pull the plug, to see if it is wet or dry.
2. Check fuel pump pressure.
3. Report back to here
Good luck.
