Need help...won't start
Old Jul 18, 2009 | 09:41 AM
FXSTDSE2's Avatar
FXSTDSE2
I would plug in the original ecm for a couple of seconds just to eliminate the possibility of a Tmax problem. A nice blue audible "snap" should be coming from the plugs. A kv tester to see what the spark is would be nice. And now we are at fuel. Pull the filter off an shoot a little brakecleen in and see if it fires. By this time you should be leading down the right track.
Old Jul 18, 2009 | 10:53 AM
dynhd1's Avatar
dynhd1
Chrome regulator covers lead to excessive heat , check the back of the regulator for any distortion in the casting. I went through 2 of them.
Old Jul 18, 2009 | 11:09 AM
stro1965's Avatar
stro1965
Regarding the regulator cover, it hasn't been on for more than 1 mile, that can't be the issue. I snuck home this morning and tried it again after letting the battery tender work all night. Still cranks but no start.
My next step, I guess, is to plug in the factory ECM, easy enough, but I assume I need to switch O2 sensors as I'm doing it? Just for the test? PITA.
FWIW, the spark looks weak to my untrained eye, and I don't have the tools to check fuel pressure or measure the spark. I will try shooting something into the throttle body to see what happens, is a tiny shot of brake cleaner the best best?
I'm seriously bummed right now. I don't want to spend my Sturgis wad on repairs before the trip!
Old Jul 18, 2009 | 11:15 AM
rockDAWG's Avatar
rockDAWG
Get a can of starting fluid from Autozone and try it. IT will rule out the ignition or fuel issue.
Old Jul 18, 2009 | 12:08 PM
FXSTDSE2's Avatar
FXSTDSE2
No, you won't need to switch o2s. You are only doing a test. Just unplug the Tmax and plug in the orignal. It will still start, just set codes. I use brakecleen at work (cars) for suspected fuel issues all the time. A 1 second squirt in the intake and it should fire if it is a fuel issue. You can pick up a cheep spark tester at a part store for under $10. This is the one I use at work. http://www.thetoolwarehouse.net/p-7200-thexton-404.aspx. Anything similar should do the trick.
Old Jul 18, 2009 | 12:32 PM
stro1965's Avatar
stro1965
Thanks for all of the info guys. Figures I'm stuck working this weekend, this is killing me! Regarding the WD40, which connectors should I concentrate on?
Old Jul 18, 2009 | 01:11 PM
oldairboater's Avatar
oldairboater
Weak spark? If you ground that plug against something good with electronic ignition it should arc bright and crisp. Stand back --start over and look at everything electrical slowly and deliberately. Assuming that the valve train still works and you have a bike still in timing with compression---that leaves only ignition and fuel. Check your ignition again and if you have fire then misting a little bit of fuel into the throttle body should get you something. A small shot of fuel and then hit the starter switch while standing clear of the throttle body. If the bike fires up then you have a fuel problem. There is always the danger of fire when adding raw fuel into an engine to bypass any means of metering. I hesitated to write this because of the hazard of getting burnt or burning down the garage. It sounds like you are trying to work on this bike by yourself and you are frustrated. Calm down, relax and think this through while trouble shooting back to your main problem. If you can't do this safely and deliberately--get help.
Old Jul 18, 2009 | 02:14 PM
oct1949's Avatar
oct1949
water turns into moisture after heated and that may be W it happened the next day.
Old Jul 18, 2009 | 02:22 PM
RHillbilly's Avatar
RHillbilly
try unhooking battery then hook it back up that will reset abreaker if you tripped one
Old Jul 18, 2009 | 02:28 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
I seem to recall people having problems with the chrome covers for the regulators a while back. I don't remember the specific problem, but my guess is that is your problem. Seeing that is all you added to the bike, pull it off and try again.
