I've about given up on Harley
  #91
Old 10-16-2009, 05:43 PM
Ky Windage's Avatar
Ky Windage
Ky Windage is offline
Saw this thread and thought I'd link to another... this has been discussed a few times on the dyna forum.
Several of us have this same thing and it's funny that for most, it started in the 5000 - 7000 mile range.
Guys have changed compensators, oil, etc... Still happens.
Read this thread > https://www.hdforums.com/forum/dyna-...ing-noise.html
No clue... maybe it is pinging. I gave up worrying about it. Bike still runs fine in spite of the noise.
  #92
Old 10-16-2009, 09:06 PM
HDSmith's Avatar
HDSmith
HDSmith is offline
Yep. My first tune was nominally 12.5 to 13 AFR WOT. Still too lean, 25-50% throttle roll-on mid-range RPM was horrible sounding. After a few months of that I got sick of it. Got lucky and found a tech that used advanced mode SERT, he gave a tune file in the ballpark from a dyno run, after a couple rides I made small tweaks to tune out the few remaining spots that pinged. The tech would do the same for shop rate, but it is not hard to make a few tweaks yourself. No pinging at any throttle on pump gas and no timing retard.
  #93
Old 10-17-2009, 12:24 PM
turxile's Avatar
turxile
turxile is offline
Yeah it's normal! Like it's normal for bikes to rust after 2 months, and for brake fluid to leak, etc etc.
What b**ls**t about not riding with your throttle fully open! New thing they'll tell you it wouldn't have happened if you hadnt ridden the bike at all.
One thing's for sure, this is not the way to do business in an economic crisis. Customers actually start caring about quality at these times, as we don't have the budgets to change everything on the bike anymore.
  #94
Old 10-17-2009, 01:25 PM
Faast Ed's Avatar
Faast Ed
Faast Ed is offline
Ky Windage, I read your linked thread and agree that it is pretty much identical to this one. While it is really hard to imagine how a noise sounds over the internet, the symtoms do point towards that crappy 07 and up compensator.
If there were a way to make a wager on this, I would bet that is the issue here and on that other thread. Replacing it with the heavier SE version is not that pricey of a deal, if you can do the work yourself. Youl'll likely get more life out of your crank too.
EDIT: Some notice it more than others, but more often than not you do get a smoother ride with the beefed up compensator.
Little bit of a pain to install but a very good functional addition for any 07 and up bike.
The factory spring pack is indeed too weak unless you ride like an old grandma.
  #95
Old 04-16-2012, 12:40 PM
Mean Gene's Avatar
Mean Gene
Mean Gene is offline
Check the "compensator-bolt" for proper torque in the primary. If loose, the crank and chain-sproket-compensator, sort of hammers on the "power-pulses". Mine came loose on my 96, sorta-kinda sounded like rod knocking and noisy sprocket chair drive. Seems a lot of problems, keeping this bolt tight.
  #96
Old 04-16-2012, 01:35 PM
Shakeydeal's Avatar
Shakeydeal
Shakeydeal is offline
Do you really think that he hasn't corrected this 2 1/2 year old issue yet?
Shakey
Muscle-man
09-21-2012 02:27 AM
bmorebhoy
10-10-2010 08:34 PM
Darkaeon
08-22-2010 03:27 AM
jahays32
05-03-2008 07:54 PM
dz672
08-11-2006 11:54 PM
Quick Reply: I've about given up on Harley
