Does Anyone Have these grips?
Old Jan 29, 2011 | 11:46 PM
stev0n's Avatar
stev0n
Default Does Anyone Have these grips?
Post pics if you do!
I just bought these and I am having a hell of a time getting a proper ground to the right/throttle grip for the turn signal. How did you get yours to ground out properly? are your bars powdercoated/chromed?
I guess this really applies to any grips with one wire, single-filament signals in the ends.
As always, any help is appreciated. Thanks Guys!
Old Jan 30, 2011 | 12:15 AM
hatchetman's Avatar
hatchetman
Are you sure that both grips have only 1 wire each? the throttle grip might have 2 wires in a single coat to ground it as well as power it.
I think their awesome!
Hatch.
Old Jan 30, 2011 | 12:36 AM
stev0n's Avatar
stev0n
thanks, they do look badass on the sled.
But it is only a single wire on the throttle side.
Old Jan 30, 2011 | 09:05 AM
Tom84FXST's Avatar
Tom84FXST
Did you finish the installation or try them as soon a you hooked them up? One would think they would ground through the throttle cables...powdercoating will things more difficult...you may have to run a ground wire.
Old Jan 30, 2011 | 10:40 AM
schumacher's Avatar
schumacher
but when you twist the throttle, the turn signal on that side would move
Old Jan 30, 2011 | 11:38 AM
wideglidebob's Avatar
wideglidebob
yeah u would be telling the birds and the animals on the ground your turning good idea but the light needs to be indepdant of the throttle twist
Old Jan 30, 2011 | 12:25 PM
stev0n's Avatar
stev0n
I finished installation, they're on the bike & the left side works ( but the left grip is snug on the handle bars with a set screw. the right grip can't be snug to be able to twist.).
When i took a multimeter to the bike to figure out the problem, then find a ground after i figured it out, the throttle cables was one of the first places i looked. But it is not a ground.
Old Jan 30, 2011 | 12:47 PM
Tom84FXST's Avatar
Tom84FXST
Might try running a ground wire to a screw on the carb...making the throttle cables grounded may be the easy fix.
kel03
General Topics/Tech Tips
Feb 22, 2017 08:30 AM
Big trucker
Sep 27, 2014 01:31 AM
louie c
Jan 22, 2013 08:01 AM
ayates1415
Jun 5, 2011 04:18 PM
oscarg
Aug 25, 2008 01:55 PM
