Sturgis oil change
Old 05-07-2011 | 08:05 PM
JayStronghawk's Avatar
JayStronghawk
Originally Posted by masterblaster
Well I was shocked at the prices they were charging at the Amsoil tent (and other places), actually a little pissed, felt they were gouging. I went to the O'reillys across the street, boought al necessary materials, Mobil 1 V $9 per qt, Blue paper towels, drain pan $3, Fram Filter cant remember but like $5. Did the oil change in parking lot, dumped oil at store recycle bin left pan behind. All of this within sight of the theiving oil changers tents, fk them. Total cost $50.
Afterwords I seen a church on the bypass street everyone uses offering a place to change oil and wash bike for free, tents and all. Good Christians there.
As others said change before you leave, I was on way back to Fla from Alaska so was due for change.
Was wondering if would see this in the Post Jerry, why checked it out .. Remember this well ...
Old 05-07-2011 | 08:12 PM
Flatbedder's Avatar
Flatbedder
Don't want to start another oil thread, but I am going to chime in here. I have owned large tractor trailer rigs for over 10 yrs. Been driving for over 25. Now I know that the additive packages in diesel oil is different for those of gas engines. Having said that, we run our oil up to 20,000 miles without changing. This is not considered an extended drain interval. Best mileage to change on a truck with dino oil is 15,000 miles. With full synthetic oil, in a motorcycle, five thousand miles is a no brainer. I run a syn blend in my Ford Explorer and it has over 170,000 miles on it. I change it every six or seven thousand. You should have no problem running full synthetic in your bike seven thousand plus miles.
Change before you leave with high quality full synthetic, run it with confidence, change it when you get back.
Old 05-07-2011 | 09:03 PM
JayStronghawk
Had a little over 6K on the oil when did the FL trip to Sturgis and back last year, oil still looked fine when draining and didn't use a drop between changes .. It should have looked good, the Oil was only 2 weeks old ..
Old 05-07-2011 | 09:31 PM
Lost1's Avatar
Lost1
Even a stout dino like Valvoline VR1 can do 5-6k with no problems, especially extended highway miles. Change it before you leave with a good dino or synthetic & change it again when you get back & enjoy the trip. Definitely not something to worry about, IMO...
Old 05-07-2011 | 10:20 PM
vtwin1340's Avatar
vtwin1340
Put syn in before you go, change it when you get back 5000 miles later. If you follow normal oil change intervals there is not substantial enough oil breakdown to cause abnormal wear or damage to your equipment.
Old 05-08-2011 | 03:43 PM
philipmcphail@hotmail.com's Avatar
Synthetic and dont worry about it,ride safe and have fun!
Motul
Vendor Announcements
07-31-2019 01:28 PM
rgjujitsu
05-28-2011 11:10 PM
masterblaster
08-17-2010 12:24 AM
DaveMK
Oil Archive (no new posts)
02-28-2010 04:45 PM
fire228
07-21-2009 10:17 PM
Quick Reply: Sturgis oil change
